Mildly lifted F-350: Toning down the bounce?
Hi everyone, been lurking for a while and this is my first time posting. Done a fair bit of searching concerning my issue, but now it's time to ask the experts!
This is my first full-size truck, first diesel, and first largish camper that I bought it to tow. So it's been quite a crash course learning all the new stuff, but I am in love with the truck (especially now that I've got a DP Tuner in there!), and want to make it work better for my needs.
The truck: Early 99 F-350 7.3 crew cab long bed, with what appears to be a 4 inch lift, on 35" BFG AT's. Has air bags in the back, too.
It's duty: Hauling dirt bikes and the occasional yard stuff in the bed, and towing a small (~5,000 lbs) toy hauler. Honestly, I really should have bought a 3/4 ton, but this was a good deal!
The issue: It's bouncy. Like, real bouncy. So bouncy that it makes it hard to press on the gas pedal consistently because my foot is bouncing off it. In the front, all I see is leaf springs/shocks, so I assume the leaf springs have been upgraded to taller ones. In the back, there is clearly a 3.5" block between the axle and the springs there.
So, what I'm thinking of doing is putting a set of F-250 leaf springs on there (with 2" of lift, like a leveling lift), and then taking the lift block out of the rear. I know it will drop the truck a little bit, but I am okay with that if it will give me some better drivability. Towing the camper should be no sweat, and if I end up getting something bigger down the road, I can just swap in the beefier suspension.
The top product on this page is the leaf spring I was looking at:
99 1999 Ford F250 Super Duty Leaf Spring - Suspension - Pro Comp Suspension, SuperSprings, Front, Rear - PartsGeek
So does this sound like a good plan? Any other ideas? Thanks for any help!
The springs are generally the same on the F250/350 other than the F350 has a taller block on the rear axle and has the overload springs standard. The quality of the lift kit will play a huge part in the ride quality of the truck as well as shocks, my 06 stock F350 was super stiff and bouncy empty or towing and after checking the part numbers on the Napa shocks I found they were actually meant for a duly truck. It still doesn't ride like a Lincoln but definitely more how I would prefer a super duty to ride and doesn't try to buck the trailer off the back of the truck anymore.
Wow, thanks for all the replies! Shocks it is, I really like the idea of getting those Ranchos and being able to tune them for what I'm doing. Little more cost (okay like 2x), but so much more versatile.
Alrighty, so shocks need to happen. Still thinking about taking the lift down to just a leveling lift, which should be simple for the rear; just take out the blocks.
The front, however, is just a leaf spring/shock. Does that mean it's the leaf spring that's giving it the lift?
I should also add that the only reason I want to reduce the lift is just to make it easier to get the bikes and other stuff into the bed. Nothing worse than struggling to get a bike up a ramp and almost have it land on you!
Don't forget about this!!!
Promotions
Info in quote below too.
Promotions
The front, however, is just a leaf spring/shock. Does that mean it's the leaf spring that's giving it the lift? Yes the leaf spring or it could be an add-a-leaf, but most likely a true spring pack. Also shocks will be for a 4" lift too.
The front springs would be part of the lift kit. Blocks in the front are a no-no.
Is the camper hooked up in your picture? The back of the truck from the looks of the picture is sitting at a fairly normal height for a F350 and the front looks a lot like my buddies old 99 with a 2 inch lift add A leaf. This is how my 06 f350 sits unloaded (stock 18" rims with stock 34" tires and no lift).
Twigs, so that's all stock? Good lookin truck btw. How about this: I'll take a pic of my front and rear axle setups so you guys can tell me for sure. I tried looking at the fordparts.com site, and there's like 5 different blocks that could be under there.
Once I get the whole spring situation figured out, I'm definitely going to order up some of those Ranchos, with that rebate they're only around $250, worth it for that adjustability.
The Rancho RS 9000 shocks are a great addition and I think will help your problem immensely. Also remember to check the pressure in the tires. Those 35" tires will not need to run nearly as much air pressure in them as the stock size. Here is a link to a document that you can use to calculate the correct pressures for your oversized tires to match the load carrying capacity of the stock size tires at the pressures listed on the door jamb/fuel door/glove box sticker.
http://toyotires.com/sites/default/f...-LT_102913.pdf
You may be surprised at how little pressure you need to run in the larger tires to have the correct load carrying capacity. I had 315/75/16 on my 2003 and I calculated a pressure less than 35 psi using the document above. Running too much air in the tires can create a situation where the suspension isn't really allowed to do its job.
As promised, here are some pics of my suspension, I would be shocked (no pun intended) if it is stock. Front:
Rear:
