Front driveshaft help
So I have a 75 hb. When I bought the pickup the front driveshaft wasn't on but had the ujoints on. I bought new u joints and new u bolts. After installing the u joints on the driveshaft, I put the driveshaft to the axle and transfer and quickly discovered an issue.
They joints fit correctly on the shaft but are too narrow for the output on the transfer case and the input on the axle.
Part #'s are: 369 for u joints from Napa
329-10 u bolts Napa
81004 u bolts autozone
The Napa u bolts fit perfect but the autozone u bolts are a hair too wide. Also my driveshaft is about 3/4" too short with the slip yoke extended all the way. All parts were looked up by vehicle info search. Any idea to what gives? Thanks
329-10 u bolts Napa
I was thinking the same about the lift for the length issue. But what confuses me, is that all parts correspond to vehicle as far as what was found at the auto parts store, but the u joints don't match on the transfer case nor the axle. So it's hard to think its the wrong d/s.
I'm not sure on the lift. Everything underneath looks stock except for new bushings on the leaf springs and hangers and what looks like an aftermarket add-a-leaf in the rear.
Were there any special parts or part #'s for the highboys?
It sounds like you have 1310's and need 1350's, from Denny's Driveshafts,
What is the difference between 1310, 1330 and 1350 Series?
The "series" of a driveshaft or universal joint is determined by the actual dimensions of the u-joint. While the front and rear u-joint can be of two different sizes the shaft is only as strong as the smaller one. The 1310 series u-joint measures approximately 3 1/4 inches wide. The 1330 and 1350 both measure approximately 3 5/8 wide. The 1310 and 1330 series can have cap diameters of 1 1/16 and/or 1 1/8 inch or a combination of both sizes. The 1350 series has a cap diameter of 1 3/16 inch and the body and journals are bigger than the 1310 or 1330. Remember 1350 is almost never found in production car driveshafts.
Ford: C5TZ-4635-F ~ Spicer: 210392-X .. Combination U-joint / 2 cups are 1310's, 2 cups are 1330's / Obsolete ~ Available from auto parts stores.
F250 4WD (High Boy) 133" wheelbase with 4 M/T & Dana 44 ~ Applications: 1973/74 240/300/360 / 1975/76 300/360 / 1977 300/351M/400.
Here are the parts catalog specs for this u-joint, scroll down to the 7th part number: C5TZ-4635-F
Hypothetically speaking, if it's the right driveshaft with the correct u joints, and assuming it's too short due to a possible previous lift, I will have to lengthen the d/s. Would taking it to a shop outweigh the price and time of trying to lengthen it or build a new one myself?
With the info that NumberDummy provided, it seems like half my issue is fixed or at least pointed in the right direction. I agree with you on the d/s too short.
