Binding in steering wheel.
I know how to check the ball joints but I'm not sure how to check the u joints in the hub. Every google search I do comes up with how to check the drive shaft u joints, those are good since they were just replaced last week. So how would I check the u joints in the hub.
It disappears when turning at higher speeds. If I'm remembering right 15 or higher I don't feel it. I feel it on both sides when I first start turning, then it sort of "releases" the wheel after about a 1/4 turn of the steering wheel.
factory size (32") tires or oversized tires?
also, remember these are big heavy monsters. How old is your truck. Both my old 2002 Excursion and old 2006 F-250 had issues turning 35" rubber when <10 mph, but any faster speeds they were fine. the power steering pumps weren't up to snuff for the larger tires.
what year is your truck? 99-04 trucks are slightly different up front than 05-15 trucks
Calvin,
The general answers here are good for your general description. What Im getting at is we need a little more info, the crystal ball isn't working. Year, model, 2x or 4x, engine/trans combo, tires/rims, if not factory. Miles on truck. Auto 4x4 (ESOF) or manual hubs? Any recent service performed etc...
If in fact you do have a 4x4, are you in or out of 4wd right now? How familiar are you with how a 4X4 reacts on different surfaces?
Calvin,
I have 2008 f-250 with the 5.4 and auto transmission. 4 wheel drive with auto hubs (both Hubs are on auto). Also just regular rim and tire combo. It has 115xxx miles on it with the only recent service being u joints on the driveshaft last week and last summer the ball joints and hub on the pass side. I do know the difference between being in 2/4 wheel drive, the truck is in 2 wheel right now. Any other suggestions?
You are at the point on miles that I(we) say its the front ujoints out by the hubs. If they are sloppy thats easy to see w/o dis-assembly. If they're bound up, as we suspect is your problem, its harder to tell until disassembled. If your getting the sensation of the 4WD bind while nothing is engaged I say its a definite ujoint bind issue.
What I and others tell everyone is...if your in that deep just plan on replacing the hub/bearing assemblies(one in your case) and the ujoints on both front shafts. Insp the ball joints (again) and steer linkages too. MAW do it all at once if you have the $. It will save you in the long run. Make sure everything gets anti-seized before re-assembly.
This bind problem generally arises due to lack of 4WD engagement and water wicking in to the ujoing due to lack of grease. I recommend these front joints get greased every 5K minimum.
Use Spicer replacement ujoints. If your **** buy a separate grease gun and buy the recommended Spicer grease dedicated for their ujoints.
