Tire and rim help
Welcome. A 265/75R15" tire is recommended for a rim between 7.00"- 8.50", and are permitted on a 9.00" or 9.50" rim. If you have stock era F-1/F-100 wheels they are likely 5.00" wide, and if you are lucky 5.50" or 6.00" in some, but in no way do they meet the 7.00" minimum. My source is a Tire and Rim Association manual. I'll defer to the dark siders on your lowering question. Stu
With that size tire, even if you got wider rims, you would not have enough clearance on the front fenders. Not only would lowering the truck be out of the question, you would have to raise it. On stock height the biggest tires that will clear on the front would be about 235/70/15 and that would be close. Oh, and if you do have the original wheels, they should be 16"
