trans fluid tytpe? and change question
Old 02-11-2016, 09:31 AM
kdwellssr's Avatar
kdwellssr
kdwellssr is offline
Its near 18 for gas engines and 22 for Diesel. The diesel one gives information that we don't need for a gas engine. The Diesel give TBN/Tan. Don't know what any of it means but I will. When I get the results I'm sure I will be back here to get help understanding the results.
  #32
Old 02-11-2016, 02:44 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
I don't get it, maybe its my distributor giving it out for free??????? IDK
  #33
Old 02-11-2016, 03:48 PM
kdwellssr's Avatar
kdwellssr
I think you are correct. Your dealer likes his customers. I sent complete messages about my purchases and they haven't responded at all. Guess I'll have to move up your way.....Not. Oh well.
  #34
Old 02-14-2016, 10:43 PM
whomrig's Avatar
whomrig
whomrig is offline
According to my build sheet, the A40D is the 4R100, this is what my rig has in it.
I currently have Mercon V in it, and all seems to be good.
  #35
Old 02-15-2016, 08:31 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,598 Likes on 1,071 Posts
Ford never made a transmission called the A4OD. There was an E4OD that evolved into the 4R100 in 1999. Your 2000 F-150 has either a 4R100 or a 4R70W. MERCON V is the right fluid for both of those transmissions.
  #36
Old 02-15-2016, 09:31 AM
1bigjoe's Avatar
1bigjoe
1bigjoe is offline
how much fluid does it take
  #37
Old 02-15-2016, 09:41 AM
kdwellssr's Avatar
kdwellssr
Depends if you drain Torque Converter... if you have a external cooler,,,and if you drain that as well.... and which transmission you have.
  #38
Old 02-15-2016, 09:46 AM
1bigjoe's Avatar
1bigjoe
1bigjoe is offline
empty-4r100 empty tc-
  #39
Old 02-15-2016, 09:55 AM
kdwellssr's Avatar
kdwellssr
I have the E4OD sorry, I figure 16 qts usually does it with very little left over to top it off or for later.
  #40
Old 02-15-2016, 10:05 AM
kdwellssr's Avatar
kdwellssr
Book says 5 qts for dry trans. Must be trans only... Torque converter likely 10 and cooler extra 1 or so.
  #41
Old 02-15-2016, 10:26 AM
whomrig's Avatar
whomrig
whomrig is offline
Thank you Mark, this answered a question I had
  #42
Old 02-15-2016, 01:49 PM
Mark Kovalsky
What book? I wouldn't trust that book, it's WAY off. If it is an E4OD or 4R100 you'll get more than 5 out just by draining the pan.
  #43
Old 02-15-2016, 03:45 PM
kdwellssr's Avatar
kdwellssr
Amsol online product application guide. Didn't say for sure they were correct or not.. Just where I got the information. Being Amsol I just kinda figured they wouldn't post something that wasn't so.
  #44
Old 02-21-2016, 06:25 AM
1bigjoe's Avatar
1bigjoe
1bigjoe is offline
ya---the parts store said 6.5 qts----- that's why I was asking
that's a lot less than 20 qts
  #45
Old 02-21-2016, 07:51 AM
kdwellssr's Avatar
kdwellssr
Sure is. The rest of my bulk was in torque converter and coolers. Most is Torque Converter.
Quick Reply: trans fluid tytpe? and change question
