Proper Hitch
Proper Hitch
So, I am looking to buy a hitch for my Ex. It has the 4" lift and the 35" tires on it, so i am thinking of getting this 8" adjustable drop hitch.
For all of you seasoned Ex towers, am I in the right ball park for drop length? Also, what hitches has everyone found to be the best quality, reliability and over all usability?
I need a good hitch for pulling a u-haul trailer in my upcoming move to the Seattle area...
Thanks!
Thanks!
David, If you can ahead of time, find out what the hitch height is on the trailer when sitting level, then verify that whatever drop drawbar you are looking at will be able to be adjusted to match that height.
I use one of these for our boat trailer and small utility trailer, it adjusts to the perfect height for the boat but is still a little too high for the 5'X8' utility trailer's hitch.
Adjustable Tri-ball Hitch | AW Direct I paid less than this for it, I don't recall where but some web shopping should find it for a better price.
The ball mount you've posted usually runs around $90 IF memory serves.
You can go really cheap BUT safe if you want at Harbor Freight. I prefer the solid H/D ball mounts (10000 to 12000 rated). H/F sells a straight, solid, tri-ball for $24 with coupon. It will easily do what you want & since you are just now looking for a ball mount I assume you do not tow often. Northern & others sell a solid, Buyers Label I use & like as well. I run a 4" lift /drop Buyers up on the stocker & down on a 6" w/37's, this type of B mount with ball should set you back about $40-$50. EITHER are over kill for this single tow your doing. Your stock receiver is only rated at 600/6000 at best and U-hall does not really rent any heavy load trailers because of the liability AS well as how few rigs could legally tow them.
Don't sweat the ball mount for a trailer/rig you don't have yet !! Good chance it will be wrong anyway I have 5 to 6 different ball mounts laying around, used when needed on not at all. You should get what you need for this trip ($25 to $50 max) I.M.H.O. U-hall may even rent a B/M for $10-$15 ??
x2 on that... every time ive looked at drop hitches for the lifted vehicles just to see if they could rate anywhere near what the regular hitches were for stock heights i noticed a sharp decline in weight ratings the lower the ball had to drop.. just something to keep in mind when your shopping.
What ever you do in the future, make sure it's installed correctly. I'm dealing with a busted up WD hitch with built in sway control right now that I'm finding the dealer installed incorrectly. Pulled into the park on Friday night and it was popping and creaking to the point other people came out of their trailers. On a side note, where you moving to near Seattle, I'm about an hour or so north.
Sorry to hear about the hitch problems, what hitch is it and what is the issue? Your TT is a pretty big unit and may be too much for a less than robust WD setup.
How is your daughter doing?
What ever you do in the future, make sure it's installed correctly. I'm dealing with a busted up WD hitch with built in sway control right now that I'm finding the dealer installed incorrectly. Pulled into the park on Friday night and it was popping and creaking to the point other people came out of their trailers. ...
