My V-10 wants to be a v-9
Hello everyone this is my first time on here i have been reading for about 2 hours now I am just wondering if anyone out there has had more than one plug blow out on there v-10 i have had 3.
My truck has 80,000 miles on it. I have had both heads replaced
I am battling with ford.
Any info would be appreicated
thanks
dustin
thanks
dustin
on
1 Post
I have heard of one truck having 2, but never heard of 3. Can you tell us your engine build date? It is located on the left valve cover. Stand at the left front wheel and look down past the brake master cylinder towards the motor. You will see a white sticker with a date on the right lower corner.
Thanks.......
Mark
Thanks.......
Mark
Thanks for the replies. I have had 3 different plugs blown out. The first one they helicoiled at 50 000 miles. Then they replaced the drivers side head at 74,000. I just had the Passengers side head changed at 78,000. Thank god i bought the extended warranty!!! I will post in an hour or so the engine build date. Thanks
on
1 Post
Dustin,
Thanks for the reply on the build date. It seems this problem is very erratic on which engines have it, and those that don't.
Do you know if the plugs hand ever been replaced, or they all still factory installed. Just curious.
I have always been told never change plugs on a aluminum head if it is even warm. I always heard to let the vehicle sit over night and replace the plugs when is was stone cold. Just .02 cent worth of info.
Mark
Mark
I had heard some bad stories about the spark plugs coming out so i never touched the plugs. They were all factory installed.
WEll I just left the Ford garage my truck is in there again. I think one of the spark plug coils is bad it has had a bad miss ever since my last head change 2 weeks ago.
Does anyone know if the K&N fipk is worth the $243.00 i have the air filter in my truck now, and was thinking about buying the fipk.
Any info is appriceated
thanks
thanks
thanks
thanks
