Should I buy or pass?
I talked to the owner and he said the truck has a vibration around 40-60mph. He said a shop told him its his torque converter. I am not 100% sure but I think that is in fact wrong. I assume the torque converters job is much like a manual clutch and if it was going out it would make a grinding noise on startup. I imagine more than likely what's causing the vibration is either a dead cylinder due to spark plug, COP, injector, injector harness etc. OR He has some bad u joints?
It's a salvage title, but I honestly don't care as long as the truck isn't a mess. The guy basically said the truck was rolled on its side and the owner had the body that's on it now put on to replace the dented body from the previous accident.
It's a limited which is a plus and its a V10. I have an extra set of COPS, Injectors, and other spare parts I could use to help diagnose the issue.
Wife is wanting an excursion, but doesn't want to pay 10-14k for a used one.
2000 ford excursion
2000 ford excursion
$4000?! If it's really as clean as it looks, I'd buy it!
I doubt the converter is the issue. Btw, the converter is basically a fluid coupler that uses ATF and stator vanes to transfer engine power to the transmission. Very simple explanation, for the most part I stand by they work on witchcraft.
Either way, you can come out ahead of a similar condition X with that mileage.
Check in the tech folder sticky up top, there's a HUGE chart on troubleshooting vibrations at different speeds, etc.
Torque covertors can cause a vibration like that. I believe it's called torque covertor shudder. My 05 F-150 had the same issue you described and it was indeed the covertor causing it. Just my thoughts. I'd absolutely buy this if its not just awful inside. The seller sucks at taking pictures.
From my recollection you basically wanted a truck you WOULDN'T have to work on or try to keep whatever repairs to a bare minimum.
The OP has extra parts and time/energy/effort/money to throw at a project truck AND he has a working vehicle to use in the meantime.
