How I put 71-73 Mustang headers in my Bump
on
ok heres some pictures finally
driver side header vs manifold
passenger header vs manifold
driver header to radius arm member clearance,
driver side header - radius arm crossmember
driver header - steering box. plenty of room here
modification to front crossmember. passenger side had to be cut down completely flat.
passenger header to frame clearance.
passenger header-cab. theres more room here than it looks like. this is a bad angle.
i was worried about the engine mounts being in the way, but theres plenty of room.
heres why the front crossmember has to be cut down so low on the passenger side.
the transmission support crossmember has to be modified. i jigged it up like so.
cut it and put 4" tubes in it.
and here it is installed. however, i should have put the tubes slightly higher for better clearance of the exhaust pipes.
on
Here is a quick YouTube vid of how it sounds.
http://youtu.be/jAVuK-jdVXQ
on
Good Job Prince (1). Not only has there been others asking for a 351C,M,400 but I assume what you did will ALSO show guys with 351W's what they can do. I have read guys saying the 302 headers won't fit on a 351W in these rigs. I think you just showed 'em what to do. Aces Buddy.
It wasn't my idea, I got it from Hio Silver. He did it on his truck and I asked him about it. Showed me how it was done.
