Excursion 7.3 dual or single exhaust?
We have lots of ideas. How big is your wallet? LOL Seriously, it has wheels. How fast can you afford to go?
Duals behind the wheel wells are a difficult install on an Excursion because of the space taken by the fuel tank. You only have a single exhaust outlet on your turbo, so it's a bit pointless anyway. You're not balancing exhaust velocity from the heads like you would on a gasser.
Is dual that much better?
Want to build her up right.
Stewart
There are plenty of good brands out there. I've seen MBRP, aFe, Diamond Eye, Silverline, Magnaflow, and RBP (Rolling Big Power) thrown around consistently.
I went with a 4" MBRP single exhaust (turbo-back) T-409 stainless steel which was just over $500 IIRC. If you want duals or bump up to T-304 stainless steel your looking at another $300+ to the price.
4" is more than enough for a diesel. 5" is bigger but you won't get any real added benefit besides a really big exhaust tip behind your rear tire. All you are doing is getting the exhaust from the engine to behind the truck so you aren't smelling it. There's not as much engineering in it as which is different than for a gas engine (resonant frequencies, backpressure to scavenge the cylinder, etc.).
As for single vs. dual. Duals cost more (more pipe and a second tip, possibly a second muffler) and are pretty much a personal appearance preference for a diesel engine. For gas engines a single will usually enhance the low- to mid-range power and a TRUE dual exhaust (each side gets its own independent exhaust) will enhance top end power. Most systems are not true dual exhausts (the exhaust manifolds collect into one point and then either split out before or after the muffler). Again, that's the rule of thumb I learned for gassers.
on
T-409 will get a rusty looking coating but not rust through. It came with a T-304 (shiny, mirror finish) 4" to 5" tip. Sharp looking.
It didn't make sense to me to spend $$$$ more for shiny that wouldn't be see, although I did insist on the Stainless Steel, being I live in the Rust Belt, LOL.
FYI. When pricing, the Excursion version is about $50 more than the truck version.
It's a tight fit, but it did clear my fuel tank and rear shock.
I am VERY PLEASED with it. A little turbo whine and a little growl. Both are more pronounced outside or with the windows down.
If inside with windows closed, not a lot to notice- just what I wanted
Good luck on your search!
