1952 Parcel Van
1952 Parcel Van
Instructed to start a new thread which makes sense. I have a 1952 Ford parcel van P35. It was ordered for the FAA. Not much info other then it was at a small airport and then a hydraulic company had it.I know it sat since 1982 then I bought it 2012.I have had no locating any body tags on it telling me who built the box. It runs good and everything works.
Looking to change out front and rear axles so I have a better selection on tires it runs 8 x 17.5. Any one out their that might have info on this Box's configuration
Let me know. It's paneled with galvanized sheets. Thanks
P35= P350 Parcel delivery
J=?? that is the parts catalog code for the same truck
H= 226 flathead 6
2= could be 52, but this serial number does not conform to anything we have seen.
The 8 lug on the front fits with a P3 or P350 but the 6 lug on the back would suggest a later P600.
If this were a 52 the serial number would start with P3H1 assuming it's the flathead 226 six cylinder
Have you got a Rating or Data plate on the truck?
Have you checked the frame for the serial number?
I don't know how much access you have to the front of the frame, but if it's a 52, the serial number would be on top of the frame rail near the passenger side motor mount, if it's a 55, as the grill is, it would be behind the motor mount closer to the shock.
OHV 6 I think it might have been changed. I will get a pic of data plate. Someone told me that the rear 6 bolt might have been part of the special order from the government agency. It also has a walk on roof and a access door on drivers side at the top you can see in pic with step near gas cap area. Thanks for the info.
I'll add my welcome, and add my 2 cents to Joe's observations. As said, the grille says 1955 or later, the 17.5" wheels say 1956 or later, and the 6 lug x 7.25" pattern rear axle says 1953 or later. It would not in all likelihood be a 6 lug x 8.75" pattern F-600 type axle but rather a standard Timken B150 as used on DRW F-350s beginning in 1953. Also, having the OHV engine could be a 1952 feature, but I must then ask if the 3 speed is a floor shift or column shift. The 3 speed heavy duty would be correct for the truck, but would be floor shift in 1952, or column shift in 1953 or later.
Edit -also, the JH in the VIN designates a P-500 in 53-56 vehicles. The 1952 P-3 was a J. Neither the 8 lug x 6.5" pattern front nor 6 x 7.25" rear would be standard for a P-500, but I suppose unique specs could exist on a government GSA bid group of vehicles.
Now if I may express opinion. The 17.5" wheels on it are a good feature, not a bad feature. They are tubeless and sought after by guys trying to get rid of dangerous two piece wheels. The 8-17.5" tires are being reproduced, and a set would seem of modest cost compared to the expense of finding alternative 16" wheels, tires, and an appropriate replacement for the Timken B150. Below is a link to the Universal Tire page for their 8-17.5" tires. Stu
https://www.universaltire.com/truck-...transport.html
Not trying to hijack your thread. On the box, I would guess Boyertown. I had a '63 on the Ford chassis, a bit longer than what you show. The body you show looks very much like what I had. Mine was a P30 chassis if memory serves me right, DRW, Built like a tank. I had final gears changed out to 4:10s by the local Ford garage. I want to say the rear end was Dana as I had several ratio choices at that time. I removed the 223 and installed a Y block. I removed the column three speed and installed a floor mount HD four speed. Lots of access to the engine room from inside. I converted mine to a motorhome/camper, pulled a boat, enjoyed it for years. The buyer headed out to Alaska.
Yes, welcome to the forum.
Wow, that is a very cool truck. You have had it since 2012? Makes me feel better about my two trucks still unfinished
Subscribed to this one, looks interesting to say the least. I really like the defroster.
The history on this truck must be pretty crazy with all the different parts, but it looks pretty unmolested.
What are your plans for it?
