1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
99 Expedition EB 4x4
Old 05-23-2015, 04:07 PM
drofman steve's Avatar
drofman steve
drofman steve is offline
our expedition has switched into 4 hi and wont come out
i can switch from 4 hi to 4 lo and back to 4 hi but i can not get it back to awd
it does not have a 2 hi position, all it has is awd, 4hi and 4 lo
we did not switch to 4 hi it did it on its own and wont come out now
any help would be greatly appreciated as we have to take a youth group out of town in 2 weeks
thanks in advance
Old 05-23-2015, 04:16 PM
alloro's Avatar
alloro
alloro is offline
Received 4,196 Likes on 2,432 Posts
It can be caused by many things, the selector switch, the relay module, the contacts in the shift motor, a bad connection, etc...
For now, pull out 30-amp fuse #104 from the fuse box under the hood. That powers the front clutch for the 4WD system and should cause the front to disengage so you can drive it. If pulling fuse #104 does not disengage the front, then the front clutch in the transfer case is broken requiring the transfer case to come out and be repaired.
Old 05-23-2015, 06:42 PM
drofman steve
thanks for the tip, unfortunately for me it didn't work. any hope it's NOT the clutch?
Old 05-24-2015, 09:15 AM
alloro's Avatar
alloro
alloro is offline
Nope, the clutch is electrical similar to how the A/C compressor engages, if the loss of power doesn't cause it to release then it is a transfer case internal mechanical issue.
cotten616
13
02-16-2021 08:35 PM
hsauto
35
11-30-2016 03:43 PM
TX76F250
10-22-2013 11:42 PM
jwhopson
02-15-2011 12:16 AM
Luzer27
04-25-2007 02:34 PM
Quick Reply: 99 Expedition EB 4x4
