1951-52 Serial numbers
#166
1951 F1 5 star extra cab
Recently bought a 51 F1. Overall, very original and surprisingly unmolested. Never repainted and everything is there.
Hoping you can help me decode:
Cowl Tag: F1R1SP13186 (matching stamping RF frame rail)
Glove Box Tag: Early style: Same VIN plus 1RC stamping lower right
Cowl Stamping: ASP24 1 18258 724
Cowl stamp is hard to read but is A (truck is raven black) SP (St Paul) 24 (gap) 1 then the 8 (overlapping) 2 then 58 (gap) 724
VIN I think I understand (thanks to this thread) but trying to decipher cowl stamping, figure out build date and any other info you can help with.
Thanks! Mike
PS: Only oddity...truck has F2 fenders on it. Nothing indicates that they were replaced but they are F2 fenders so?? Nothing else about the front end appears anything other than stock factory (hood, core support, etc.) Any chance they were a factory 'oops'. If not, they have been there forever.
Thanks! Mike
#167
Took a closer look
Looked a little closer at the cowl stamping today. Looks like it actually reads ...SP 21 but the following letter (month code) still looks like a straight line. Thought maybe that was a poorly stamped M.
Based on 303FordGuy's truck (21M stamping, VIN F3R1SP10563), they would have to have been produced the same day,though, if it was a M. My VIN is 2623 units later than his so that's not realistic for a single day production run.
The month stamp doesn't look like a partial stamp A at all (and Jan 21,'51 was a Sunday) but I suppose it could be a partial B if anything. Would Feb 21, 1951 be likely given the F1R1SP13186 VIN? That would mean 2623 trucks produced in St Paul in two months.
Thoughts anyone?
Thanks,
Mike
Thoughts anyone?
Thanks,
Mike
#168
#169
F1= 1/2 ton
R= 239 cu in Flathead V8
1= 1951
HM= Highland Park assembly plant
73377=production number
27L= 11/27/1951 Build Date
DD2961= internal plant code
Your data plate should have the paint code stamped on it.
#170
You are correct, it would not have a cowl stamp or tag as the Data plate was changed in early September 1951.
F1= 1/2 ton
1= 1951
#172
#173
#174
#175
#176
#178
Rating Plate (Glove Box)
5700 GVWR
F2= 3/4 ton LD
H= 226 cu in 6 cylinder flathead
1= 1951
RH= Richmond, Ca Assembly plant
18508= Production number
Patent Plate (firewall)
F2H1RH18508 (same as above)
RIC= Richmond Plant
Firewall Stampings
RH=Richmond
F2= 3/4 ton
H=Silvertone Gray (paint)
20F= June 20,1951 Build Date
6147= Internal plant code
5700 GVWR
F2= 3/4 ton LD
1= 1951
RIC= Richmond Plant
Firewall Stampings
RH=Richmond
F2= 3/4 ton
