Can someone identify these parts?
Along with my 1970 F250 highboy with a 300 six, the previous owner gave me a bunch of parts. Most I've been able to figure out but a few have me stumped. Can anyone lend a hand? Bill, are you out there?
Looks like some type of relay. Just don't know where it goes.
Do these go behind the grill? If so what is their purpose?
#1 appears to be a tailgate hinge for a flareside.
#3 are pilot bushings. They go into the back of the crank to accommodate the input shaft of a manual transmission.
#4 are aftermarket grill inserts for that custom look. They're worth a few bucks to someone looking for a set.
#6.. hmmm. The only thing I can recall in these rigs that has a shoulder bolt are the seat belt bolts. But there's not enough thread left after the bolt's shoulder bottoms on that bracket. They're black... look around for a blank spot!
#1 looks like 1948/79 Flareside tailgate bracket, but...it's aftermarket. Genuine Ford brackets do not have a figure 8 mounting hole.
#6 look like brackets used to R & R engines. Assembly line workers sometimes left them in place after installing engines. They're not seat belt related (see pic).
#5 is not your T/S switch if the ID number on the paper tag is D1T?-13341-AA (cannot make out the 4th digit of the prefix): D1TZ-13341-A T/S switch: 1971/84 F500/750.
This is correct: D0TZ-13341-B .. T/S Switch - Marked: D0TA-13341-A = 1969 F100/350 from serial number G30,001 / 1970/72 F100/350.
