d44 gear swap 95 f150
I have a 95 f150 with 3.08 rears I have a parts truck that is a 93 with 3.55 rears I was wondering if I unbolt the whole housing from the I beam can I just bolt it on my 95 I beam and be done it seems that way being all the internals of the differential stay in the housing and the I beam just acts as a cover but I haven't ripped it apart yet and was just wondering if anyone had any insight
advice is appreciated thanks
Picky detail, not to pick on you but to help you (and others) understand to avoid possible confusion, but 4wds do not have I beams, that's the 2wds. It's called an I beam (in the 2wd twin I beam suspension) because its cross section is shaped like the letter I. Ford sorta copied their twin I beam suspension in this 4WD design and called it Twin Traction Beam.
oughtsixbigred
11-20-2017 10:45 PM
Cope
02-19-2002 01:48 PM
Johns331
10-04-2000 07:33 PM
