APOC LED HEADLIGHT CONVERSION ANYONE TRY THEM?
#31
#37
#38
December | 2014 | Better Automotive Lighting Blog
It seems like this might be a solution for it, I will have to look into it more.
Have you used these before?
#40
They are easy to make you own if you have a ferrite core.
Let me see if I can find a photo of a simple one. here is a
technical PDF if you want to read more on it.
http://audiosystemsgroup.com/SAC0305Ferrites.pdf
Now here is a forun that is talking about how to use one
Reduce HID ballast radio interference
Looks like this is written with easy understanding in mind
RFI Problems
here is the core that they are using is just snaps together.
I won't give you any more headaches tonight.
Sean
RFI Problems
Sean
#41
#44
Sorry about all the headaches I caused with post.
I don't work for them but you can get some nice
meds at Walgreens.
I had a set of HID fog light ballasts that really liked to
sing on the AM. Was rally a killer when trying to get local
trafic reports. But I got rid of that set and went with a newer
unit and it really quieted down. The cheep ones tend to really
be the most offensive when it comes to noise of AM broadcast.
I have not ran into any that mess with FM but they may be out there.
One thing I did do and I forgot to take a photo of it was when I had
the noisy ballast set was to take the oscilloscope and look at what
was coming over the 12 volt power in that truck. WOW it had some nasty
spikes when it should of been a totally flatline. That is all do to the lack
of any filtering and that is why they cost less.
Sean
meds at Walgreens.
Sean
#45
