Long story short, we moved our batteries to the bed of our truck when we finished our conversion.
We picked up 15 ft of 1 gauge welding cable and ran from under the hood back to the batteries. It's not thick enough I don't think because it takes longer to crank.
What do you recommend we should upgrade to and where can I buy it?
I'm thinking it's the wire size but to confirm that take a voltage reading at the battery when cranking and at the starter, if you have a large voltage drop and the grounds are tight you need larger wire. Remember your ground has to be the same size.
