new oil & battery computer reset
Resetting oil system instructions are in your manual. I think that you turn the key off... then to "on" but don't start it and floor both the brake and gas for 25 seconds or something like that. Again, it is in your manual.
Concerning the battery issue... holy cow did Ford screw us with the battery box placement. You have to remove the air box, the front wall of the battery box and then you can check your battery fluid levels or replace the battery. To avoid the nonsense of resetting whatever with the dealer computer etc... just buy one of the .99 gizmos that plug a 9V battery into your cigarette lighter. This is a temporary way to keep "juice" in your electrical system. But beware because the 9V can drain very quickly if you leave a door open or leave the key on.
Best of luck to you. Did you buy the S, SE, SEL or Titanium trim level?
That's not the same thing. The battery's charge is adjusted for age so when replaced, it must be reset. The 9V battery would only help if the battery needs to be disconnected/removed and reinstalled. I have a cord that connects to the OBD port and a jump pack will last forever.
How, you ask. They don't release info like that. That stuff is so new that probably the dealer can only do that right now. They sometimes charge $100 for a diagnostic but for a battery reset might be less. If you buy a battery from the dealer they may do a reset free. I think this just started on the 2013 model year so those batteries should still be good.
tseekins
01-02-2009 06:51 PM
stevo410
2004 - 2008 F150
05-30-2006 10:37 AM
