Oil Catch Can?
I have a catch can on my 2012 Dodge Challenger and it does a great job separating the oil and keeping it from returning to the intake. I empty mine every month.
BUT WORDS OF CAUTION: I have heard stories of Ford not wanting to cover warranty repairs to engines, in direct conflict of the Magnuson-Moss Act, in Mustangs with aftermarket accessories. Including catch cans and cold air intakes.
Oil Catch Cans | Everything you need to know and more!
Many required drilling and such.
You are removing factory installed parts and altering systems.
Ford sure did not approve it.
Actually if i owned ford, i would void the engine warranty of any vehicle with one installed.
If ford wanted a catch can on their vehicles or deemed it necessary they would have already done it.
It is modifying the engine so yes.
Most Mopar dealerships are not gigging people on having them. The only altering of the system was splicing into the PVC return line. It adds nothing to the engine. It's not a power adder. All it does is catch the engine oil that vaporized during the normal operation of the engine and prevents it from gumming up the intake. Mine, on my car, didn't need any drilling. I bolted it to the fender wall.
Modifying the engine voids the engine warranty.
Ford still has to warranty the wiper switch or other parts of the truck correct.
But modify the engine and they can surely deny that part of the warranty.
Read the Magnuson-Moss Act closer.
Now how is adding a whole new system not doing a modification?
Lets see you and your lawyer argue it in court?
If I was betting on the outcome my bet is placed with ford.
But hey since I will never ever ever use a catch can at least my warranty isn't affected.
on
Ford does recognize the benefit of a catch can on the 5.0 Coyote engine, but does not endorse its use on street driven vehicles. Ford Racing Mustang 5.0L Coyote Oil-Air Separator (11-16 GT) | M-6766-A50 | Free Shipping! I have the passenger side JLT catch can that also uses factory connectors and can reversed back to stock in 30 seconds. There is no harm it can do. I has only positive benefits and leaves no "foot print".
Understood and agree, simply for conversation, plugging the manifold fitting and venting, using the valve cover vented to open air, or even adding a hose to run to filter or catch can? Drain the catch can or change the filter, greater benefit than running back to be burned in and through the intake. Just conversation Non boosted, NA engines of course.
Don't you want a working PCV system to maintain a vacuum on the crank case? That actively pulls the bad stuff out, and potentially reduces the chances of oil leaks.
And besides, there were days in the "good olde days" when I could not see across the street in parts of Los Angeles, and my lungs hurt and eyes watered from breathing too hard, all because of noxious emissions. I do not cherish those days.
