Alternator
Old 05-13-2015, 07:56 PM
bizzelj's Avatar
bizzelj
bizzelj is offline
Again I appreciate the help guys.
Old 05-14-2015, 08:51 AM
david0505's Avatar
david0505
david0505 is offline
alternator
Hi,I got my NEW Bosch 7606N 135A at Amazon $152. lifetime warranty..prime shipping if You are a member...good luck,David
Old 05-14-2015, 09:31 AM
kbf1961's Avatar
kbf1961
kbf1961 is offline
Originally Posted by texastech_diesel
Alternator Options:
https://www.ford-trucks.com/forums/1...ernatives.html
DC Power Alt and Wiring upgrade info:
https://www.ford-trucks.com/forums/1...epair-com.html
Belt tools:
GearWrench 3680 Ratcheting Wrench Serpentine Belt Tool - Combination Wrenches - Amazon.com
Amazon.com: Wilmar W84010 Serpentine Belt Tool: Home Improvement
I have the one in the second link, but for the alternator on the 6.0L you can really just lift the belt on and off the alt without messing with anything. Or use a pry-bar to lift the belt up and off like how is shown in Rusty's link above. But if you feel like you need to, either of those tools will help you set the tensioner kickstand (pics below) that keeps the belt slacked while you change out the alt.
Belt routing and tensioner:
Kick stand NOT set (belt tight):
Kick stand SET (belt loose):
Great pics! Thanks for posting. Reps
Old 05-19-2015, 09:28 AM
Fordee60's Avatar
Fordee60
Fordee60 is offline
When I change the alternator in the 6 liters, i tie a rope on the belt and tied it to the hood latch up top to keep the belt from falling down.
I then take off the two front bolts on the the alternator, and then loosen the back bolt slowly. The alternator will start to tip forward (no, it doesn't strip bolts or anything like that) and then the belt will loosen and the rope will keep it from falling into the engine. I just reverse the process when putting it back in. Works like a charm for me everytime. I've done dozens of them.
Old 05-19-2015, 10:20 AM
bizzelj's Avatar
bizzelj
bizzelj is offline
That's sounds like a good plan to me. I'm getting to mine when work slows down a bit and I'm off
Old 05-25-2015, 05:11 PM
bizzelj's Avatar
bizzelj
bizzelj is offline
Well finally got the time to take it off and have it tested at oreilys guy is having a hard time lol. Had it tested earlier with it on the truck and it failed and the passed and failed again so here I am
Old 05-25-2015, 05:20 PM
bizzelj's Avatar
bizzelj
bizzelj is offline
Well now it passes on the Bench test
bizzelj's Avatar
bizzelj
bizzelj is offline
Not sure what to do now
Old 05-25-2015, 05:41 PM
diesel_dan's Avatar
diesel_dan
diesel_dan is online now
If it was me, I'd replace it. It was intermittently failing in operation, ditto when tested in the truck and you think something has changed because it can pass a bench test? It intermittently "passed" in operation and in the truck (that is the opposite of sometimes failing).
No question in my mind it'll go back to the same: sometimes works and sometimes not, if you put it back in.
replace the dying alternator...
Old 05-25-2015, 05:51 PM
bizzelj's Avatar
bizzelj
bizzelj is offline
Bought a new one putting it on now
Old 05-25-2015, 05:52 PM
diesel_dan's Avatar
diesel_dan
Did you go for at least a 140A one?
Old 05-25-2015, 07:10 PM
bizzelj's Avatar
bizzelj
bizzelj is offline
I am having issues doing it this way
  #28
Old 05-25-2015, 08:59 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
I pulled up on the belt and used a bar to tap the stand under, then a piece of string or rope to hold the belt up and keep on all all the pulleys. If you have trouble, take out the passenger side batteriy, be sure to cover the cables, and then you can have someone reach down from the battery side and hit the kick stand under while you pull on the belt. It's a hard pull, but stick with it.
  #29
Old 05-25-2015, 10:04 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
The bench test spins an alt at high idle so they usually pass on bench and fail at idle in the truck
Had this same issue before watched the guy haul it to 3 diffrent shops LOL
  #30
Old 05-25-2015, 10:57 PM
bizzelj's Avatar
bizzelj
bizzelj is offline
Finally got it I took it off the small smooth pulley lifted it up over the alternator and had then pulled the crap out of it and had my wife slide it back over ther little pulley under the alternator so big thanks to her. Time will tell of it fixed my random batter light
Quick Reply: Alternator
