1964 F100 Power Steering Options
Folks, what are you using for power steering? My son and I are working on his stock 64 and would like to add PS. I don't see a lot of options for the mid 60's trucks however I read somewhere that some were using the gear boxes out of the F500/600 trucks.
any ideas?
any ideas?
I'm in the process of doing this conversion on my '66 F100. Just a couple days ago I pulled the steering gear, pump, hoses and linkages (from gear to the steering knuckles) from a '76. I also took the steering column. My main guide here is the site called "Fordification" which has a good tutorial on this conversion. I suggest you google it and go to the "technical articles" link. You'll find it there.
I started by ordering the CPP5760PSK-OC. Order guy noticed that it didn't match the CPP6164CBK5.5 disc brake kit I had just ordered and asked about it.
When I told him what was up, he changed out the rag joint in the kit for a universal joint, and then he recommended the column saver kit when I told him I intended to cut the column off the old steering box. Then he asked about the pump, and sold me a pump with the correct brackets for my motor.
As to cost, not sure at this point. I get a jobber discount from them, and there will be added freight costs. At this point they've only charged my card $100. We'll see what happens when it ships.
