Sudden no start, Low ICP, High DC%
Changed the oil this morning, fired up normally after, and shut down with nothing out of the ordinary. Two hours later, no start. ICP is only 200psi, DC goes to ~55%.
HPOP is and stays full. Pulled and cleaned IPR thinking it was likely stuck, did not find any debris, and same conditions after reinstall. Tried unplugging ICP, no help. Frustrating.
Have not pulled valve covers yet. Any ideas appreciated.
Thanks for the input so far. What type and size are the HPO fittings? As in, what do I need for plugs?
I was thinking I'd pull the HPOP drive gear cover and see if it's still bolted tight.
HPOP is my original 15 degree case that Joey put 17 degree guts in maybe 6 or so years ago. It's had a problem once before, but it still ran. After Joey fixed it that time I've had no issues since.
I pushed it into the barn and blew the grit off the top of the motor but haven't started yet.
The IPR plug was getting soft and the insulation on the wires was getting gooey. I replaced the pigtail end but that didn't help. I did plug my test light into the pigtail and it lights up with key on and got much brighter when cranking, so I'm pretty confident that the IPR is getting the signal. Tomorrow I'll see about putting a mechanical guage setup together.
Dumb question time, if the IPR itself is bad, stuck open, etc., will that leak be small enough that the pump still ought to make plenty of pressure with the lines plugged? In other words, do I need a good IPR in order to assess the pump health or will that be obvious even if the IPR is hosed?
I plugged one HPO line and put a guage on the other and barely made enough pressure to move the needle on my mechanical guage, about 200psi again.
So at this point it seems as though the pump has kicked the bucket.
Now, do I send it back to Joey to see if it's fixable, or call it used up and go for an Adrenaline or T500?
My biggest fear is how did it die, and did it send a bunch of debris into my heads and injectors.
