Starts fine after shifting engine revs
My 76 f250 developed a new problem. Go figure.. Truck has always idled high but lately when I drive around the block after releasing the clutch when up shifting and expecting the engine to drop in rpms it revs even higher. If I tramp on the accelerator it kicks back down. Is this a vacuum advance problem on the distributor or a vacuum problem in general? I'm running an edelbrock 1405 carb and the truck has had fuel problems in the auxiliary tank so I'm running off the aft tank.
ErrorS
01-02-2008 06:26 AM
JoLEE55
12-07-2003 05:57 AM
