Transmission/clutch issues
I think I may be majorly screwed. My 1983 F100 with I6 and 3-on-the-tree has been performing like a champ. I even took it on a 75 mile trip recently and got about 18mpg for the trip. Everything is going well. I got past my electrical issues, installed some lights in the bed, installed an ice chest, I've been hauling the kayak, etc. Everything was going well - until the trip home yesterday!
Approaching a red light I pushed in the clutch and to my surprise and disappointment the pedal didn't come back up. Fortunately I pulled into a parking lot and shut down. From what I can tell it looks like a rod has sheared off in a housing. Anyone else have this issue? What is my next/first move? Is this the major event that I am concerned it is? Am I going to have to drill and tap to fix this? I haven't really had a chance to look closely at the issue but I am concerned. Am I correct assuming this is a C6 transmission? Any advise would be appreciated.
Thanks - Drew
Thanks - Drew
Looking at the situation last night the sheared off rod appears to be cast, so hopefully somewhat soft. I'm going to try to back it out today, but I'm not real optimistic. It only appears to be some form of pivot point. The other end of the broken rod has a bushing. Anyone know what this part is so I can try to find a new one? The whole thing is probably about 5". Thanks
http://www.ebay.com/itm/Goodmark-Mounted-on-Engine-Clutch-Bellcrank-w-Bellcrank-Pivot-Ball-Stud-New-/301557923362?hash=item463640be22&vxp=mtr
http://www.ebay.com/itm/Goodmark-Mounted-on-Frame-Clutch-Bellcrank-w-Bellcrank-Pivot-Ball-Stud-New-/301622169353?hash=item463a150f09&vxp=mtr
this is what they are called (reference name only, cant find your actual part on ebay yet), should be easy enough to drill out the bolt and EZ out it
