94 f150 master cylinder
Old 05-14-2015, 06:18 PM
ifrythings's Avatar
ifrythings
ifrythings is online now
Originally Posted by FordRun
we starting to think its the ABS Hydraulic Assembly. if you unplug the plug from the ABS Hydraulic Assembly will it disable it ?
If you unplug the abs unit you will disable abs but you will have done nothing to the hydraulic system itself and will gain you nothing. If you suspect the abs hydraulic valve is bad you can remove both lines and connect them together with an adapter for testing. Other then that have you replaced the rubber lines as they can fail and act as a check valve the give you no breaks or stuck brakes.
Old 05-14-2015, 09:27 PM
FordRun's Avatar
FordRun
FordRun is offline
re
ty for reply.
its at shop and they want me pick it it up not fix
I will try what you said ty.
Old 05-21-2015, 05:17 PM
FordRun's Avatar
FordRun
FordRun is offline
just had truck tow back home. today shop to busy. I will try find hydraulic valve must be under the truck.
Old 05-23-2015, 04:15 PM
FordRun's Avatar
FordRun
FordRun is offline
re
is it anyway a bad tekonsha brake controller to cause it to lock one my wheels on the rear tire on truck ? it not digital one . when you press the pedal light come on . that it. it use to slide it had flat ****. now it don't slide at all . just light lights up. it always slide even without a trailer. when I got truck someone had cut plug off at rear truck. it have reg trailer brakes. I just use that one. the brake controller stuck to right. and under controller it has wheel no info on it. it also has 1 to 5 min fine I tried moving them didn't do anything.
Old 05-25-2015, 02:35 AM
FordRun's Avatar
FordRun
FordRun is offline
it was the abs hydraulic valve . also had get new drums both wheels ty for the help
Old 05-26-2015, 04:29 PM
FordRun's Avatar
FordRun
FordRun is offline
took hydraulic valve apart clean it. brake not stuck now. BUT drum is hot. drum worn . so if drum is bad will it cause drum get hot ?
Old 05-26-2015, 08:32 PM
FordRun's Avatar
FordRun
FordRun is offline
someone said change out abs speed sensor on rear
ksteak
1997-2006 Expedition & Navigator
06-07-2010 07:41 PM
dogg16
Bronco II
09-14-2004 04:19 PM
Sf006
1978 - 1996 Big Bronco
09-17-2003 10:07 PM
Quick Reply: 94 f150 master cylinder
