Normal to smoke after replacing o-rings?
Old 05-04-2015, 01:27 PM
85Supclub's Avatar
85Supclub
85Supclub is offline
Hey everyone, after replacing injector O rings I am still seeing a little bit of blue smoke at idle. How long does it take for the system to get to normal?
I probably only have about 40 miles on the Alliant rings I replaced over the weekend. The truck use to smoke blue very badly at startup unless the engine was nice and warm.
Now I have about 95% less blue smoke at cold startup, and it does a wispy blue smoke for a couple minutes when cold. I noticed at the end of my 18 mile commute, some blue smoke came back at a stoplight.
Could this still be things seating in? I read you need to drive the engine hard to really get things all bled out.
Thanks
Old 05-04-2015, 01:30 PM
madMatador78's Avatar
madMatador78
madMatador78 is offline
Its very common. It can take up to 200 miles to work the air out of the system/get back to normal.
Old 05-04-2015, 01:37 PM
85Supclub's Avatar
85Supclub
Cool. Good to hear. It definitely seems better than it was but I was hoping it would get even better. Drive it hard? Drive it normal?
Old 05-04-2015, 01:38 PM
lemonshindig's Avatar
lemonshindig
lemonshindig is offline
Blue smoke is probably from residual oil that got into your fuel passages when the injectors were out. Sooner or later it *should* clear up.
Old 05-06-2015, 06:00 AM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
Or you still have oil in your fuel tank caused by your old o rings.
cokecrazed007
1999 to 2016 Super Duty
10-26-2008 10:43 PM
jmunkie13
01-30-2007 09:52 AM
Dsl Lover
04-10-2006 11:55 AM
ALL BOY
12-05-2005 07:18 AM
rocco913
11-11-2005 01:24 PM
Quick Reply: Normal to smoke after replacing o-rings?
