crew cab weight with 7.5L? Need towing specs/capability
#31
gotcha covered on the hydro swap
https://www.ford-trucks.com/forums/1...st-brakes.html
good luck.your gunna love it!
#34
OK, so weighed truck tonight.
Great news!!!
CAT scale with both tanks full of fuel, me siting in front (280#) and buddy sitting in back seat (260#). Also, I have a camper shell (see my avatar).
Front axle: 3540#
Rear axle: 3040#
Total weight: 6580#
Now if I remove passengers (540), shell (est. 150) , and fuel (190), truck weighs 5700#
But for towing purposes, let's use the .................................................. ...6580
My buddy weighs more than my two kids combined... 2 kids (210); dog (20)....-30
camper shell............................................. ...........................................-150
wife.............................................. .................................................. .....120
hitch............................................. .................................................. .....150
ice chest, gear in truck............................................. ................................75
Total............................................. .................................................. ...6745
Truck GVWR.............................................. ..........................................9200
Truck, fuel, passengers, grear in truck, hitch...........................................-6745
Available payload........................................... ......................................2455
With these numbers I am still under my axle ratings (FT: 4000; Rear: 6048)
So, I can tow a 5er with hitch weight up to 1600 comfortably and with a loaded weight of up to 8255 (6745+8255= 15000)
or
up to 11,755 loaded if I change rear axle to 4.10 which would also increase hitch weight to around 2000 which is still under the 2455 I have available
This is great news for me as I was feeling depressed that my F350 could tow a 27' 5er!
Now, what is depressing,........................the 5er I was looking at sold today
So, the search for a clean 5er continues, with a renewed enthusiasm that my truck can get the job done!
So, do my numbers add up or did I miss something?
Great news!!!
Front axle: 3540#
Rear axle: 3040#
Total weight: 6580#
or
#36
#37
#38
Other than the potential legal issues if the manufacturer's GCWR means anything to the highway patrol, I wouldn't suggest being in such a hurry to stick 4.10s in it. That ain't a cheap swap, so you might as well know you need it before you spend the money.
I know that I'm in the minority here who think that lower gears aren't always necessary, but I'll give you my opinion, knowing there are other valid opinions out there. An E4OD in overdrive with 4.10 gears has a total final drive ratio of 2.92:1. So anything you can pull with 4.10s in overdrive you can easily pull with 3.55s in drive. And even if you need to drop to drive with 4.10s, you're halfway there in drive with 3.55s already. So I'd suggest trying it to see what you think of the 3.55s first. You can always swap gears later.
I will admit that the trans will see more heat when starting out with 3.55s than with 4.10s, so if you do a lot of stop / start the 4.10s will have another advantage. And if essentially all of your driving is towing then it makes more sense to optimize the truck for towing (and 4.10 gears will be better for towing that load, no question). But for me, with the small amount of towing I do vs. the much larger number of miles I put on with a much smaller load, I'd rather be optimized for running almost empty and put up with a little less performance, and needing to downshift more often when I am hauling.
#39
#41
Thank you to all for your input.
BTW....I get 14 mpg on the highway with my 3.55 loaded with full fuel, not towing anything. I like the 14mpg for such a large heavy duty truck.
As Bob and Brad stated, I am going to leave the 3.55s in place and see how she does once I get a 5er and start towing.
NOTE: Amazing to me that my truck (crew cab, long bed) empty (no fuel or passengers) is 5700 lbs.
#42
pretty damn crazy when you think about it, especially for a truck the size. But definitely nice so you can have a few extra pounds towing.
#43
#44
on
though i agree,i don't think id be in a hurry to swap to 4.10's either.however with a 27' 5ver id pretty much be prepared for them,and start sourcing my rear.
AKHunter93
27
05-09-2016 04:42 AM
alberta46
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
02-01-2006 01:27 PM
KLINE925
03-10-2005 02:15 PM
2003150
09-28-2004 01:26 PM
LAUDY
08-08-2004 12:19 AM
