Decode and advice
Decode and advice
Hi all, I'm the proud owner of a 1951 f1.
I was wondering if you all could tell me what I have.
The numbers are as follows
F1R1MP18001
MPC 31A24012
EABG049D B88
Vin, engine and body numbers.
It looks very solid and original.
I was thinking of putting in all modern running gear or should I stay original.
F1R1MP18001
MPC 31A24012
EABG049D B88
F1R1MP18001
MPC 31A24012
EABG049D B88
F1R1MP18001
MPC 31A24012
EABG049D B88
F1R1MP18001
F1= 1/2 ton pick up
R1= 239 cu in Flathead V8 engine
MP= Memphis (Tennessee) Assembly Plant
18001= Serial number
MPC 31A24012 I am assuming these are the stampings off the firewall, if so
MP=Memphis
C= This would be color code, there was no C, so most likely G= Sea Island Green
31A=January 31, 1951 build date
24012= Plant production number for the month
EABG049D B88 is just casting numbers for the heads. EAB indicates heads built after 1950
Thanks Joe , I didn't expect a quick response . It must be a G letter then . I'll check in the morning . I am really looking forward to restoring it over the coming years . I plan a full nut and bolt resto but I'm in 2 minds whether I utilise modern ford engine /transmission . I'd like some feedback from other members on there thoughts especially when it comes to value as this car other than colour seems to look original .
I'll have a look for the old colour.
Nick
Nick
Nick
Nick
1948-1960 FORD TRUCK COLORS, NAMES, AND CODES
Welcome to the forum! I see in your profile you're in Australia, you should add that to your Location in UserCP. We have several other AU owners who will be able to help you.
Your heads are really EAB6049, indicating the last iteration of the flathead V8, and generally considered the best. The block and such could be something else, but those are desirable heads. That's what I'm running and it has been a very good engine. I'd at least give it a chance before yanking it out for something modern.
Welcome Nicholas!
Thanks for the pics - looks like a very solid truck. Before you do any changes or upgrades - and assuming it is safe to drive as it sits today - my suggestion would be to just put some miles on now. With some experience on the road, you'll get a great sense for all the performance elements with the stock equipment. This allows you some enjoyment prior to any time/money commitment. Me, I do like the stock restorations and do understand that not every truck can be kept original - either way, the call is yours.
Thanks everyone I appreciate your input .
Nothing could be worse than to wreck a survivor . I am amazed at how solid it is . I am planning to convert it to a 12 volt and put a kit through the carby - does anyone have a link where I can get one ? It does start - reluctantly but when it does it runs clean . I'll get it up on a hoist and have a look aswell . I also believe that ford did import these into Australia back in the day right hand drive - i came across one a few months ago .Thanks and I'll keep you all posted . -
Greeting from another Aussie, you'll find a lot of great help and support here mate. Looks like a nice solid truck, and you are right, Ford did bring some of these into Aus, my F3 is original right hand drive.
I can see the appeal of a modern driveline but the original flatties have a lot of charm, sound amazing and will keep up with traffic no worries.
The hood ornament is a generic piece, doesn't belong to any specific make and can still be bought new.
I give up: what is a "kit through the carby". I can't help you find one if I don't know what it is!
