WIDE 16" Tame Treaded Tire Help / Info
These tires appear to be about a 16/36 MT Baja Claw tire.
Can anybody verify that ??
*Borrowed Innernet Pic *
MT no longer makes a size close to this :-((
They do make a 375/65-16 MTZ which is MUCH narrower.
Does anybody kno of a TAME Treaded tire this wide & NOT over 37"
Tall ??
I Know Super Swamper Boggers makes a 16/35-16 but I'm OUT on Rough Treads.
Tall ??
Tall ??
Tall ??
I have the 375/65-16 MTZ's on my truck, a friend had the Baja 36x16's. The difference in the tread width was about a 1/2 inch. My tires appeared wider because I have 12 inch wide rims and his were mounted on 10 inch. His sidewalls were sucked in, tread wore out in the middle, and overall it gave a narrower appearance. However, I would never run that wheel tire combo on a truck I was using. Rims look to have 0-2 inch offset for 15 or 16 inches of rim. To hard on the truck IMO. BUT if you like it then by all means run them. Just be prepared for added expenses.
Not especially. But you've been a member here for about 12 years before your 25th post which adds absolutely nothing to the conversation. All it does is insult someone else's taste immediately after he's said "hey, don't just make stupid posts to insult my taste."
