1969 F250 7.3l swap
Old 04-20-2015, 05:06 PM
ihf-350's Avatar
ihf-350
ihf-350 is offline
1969 F250 7.3l swap
Here she is hopefully will get to start soon I will be getting the motor and trans sometime this week. The motor is an 89 7.3 160k miles it had a seized ring and comes with rebuild kit new injectors and ip pump and a 2wd zf5 for $600. The truck is a 1969 f250 ranger with a 460 needs a distributor and carburetor with a c6 behind it $500. Was running when po sold the distributor because a friend needed it. I know the po personally so know it's the truth. It has been converted to disc brakes up front and a Dana 70 out back with 4.10's. The floor pans have been replaced and there are minor body flaws. The interior is pretty decent with new carpet and factory seat with a small tear as seen in the pics below the dash has not been cut for a new style radio so I can go back with the original style. It also has a new windshield and no cracked glass and the door seals look good and completely new brake system.
y
The following users liked this post:
Old 04-20-2015, 09:11 PM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
Cool, keep us posted on this swap. Questions about an IDI into a Bumpside come up once in a while and it'd be good info to have.
Love to do it to my '69 as well, but so much other stuff in life will most likely keep it from ever happening.
Old 04-20-2015, 09:17 PM
ihf-350's Avatar
ihf-350
ihf-350 is offline
Well the po put risers in for the 460 and in my 92 and 90 they bolt to the same holes the only thing I will have to fab is the tranny crossmember for the 5speed hopefully I know I will run into something I didn't think of but that's what FTE is for
Old 04-20-2015, 10:07 PM
Chevy_Eater
I was reading somewhere not too long ago that you might have to raise the cab from the frame a bit to get the clearance you'd need, particularity on the 2wd. Don't know if that's accurate or not though.
Old 04-20-2015, 10:13 PM
ihf-350's Avatar
ihf-350
ihf-350 is offline
Hope not but thanks for the heads up this will be a pretty large project but if I do need to lift the body that would be a good time to box the frame
Old 04-20-2015, 11:17 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
someone on this site has a good quote from Henry in his sig;
Henry Ford — 'Whether you think you can, or you think you can't--you're right.'
very cool project.like a cool factor of a A freaking +! good luck!
Old 04-21-2015, 03:57 AM
IDIoit's Avatar
IDIoit
IDIoit is offline
better get a powersteering set up for that badboy!
awesome truck!
i have a 71 F250 CS that i would love to swap, but its been in the family too long, shes staying stock.
i have a granny low box (T18?) and it looks like its not too far off from a ZF5.
shouldnt have an issue until you decide to throw a turbo on.
i would highly advise that you get a turbo now if you dont have one. atleast for mock up. youre going to need to do some clearance work.
may also need a custom trans access panel.
good luck
Old 04-21-2015, 10:41 AM
Realslowww's Avatar
Realslowww
Realslowww is offline
I would love to do something like this too.
Old 04-21-2015, 11:49 AM
ihf-350's Avatar
ihf-350
ihf-350 is offline
awesome truck!
good luck
I think it already has ps since it has a small steering wheel I didn't look to close under the hood since it's all coming out
Old 04-21-2015, 12:31 PM
IDIoit's Avatar
IDIoit
IDIoit is offline
perfect time to clean up the firewall to floor pan pinch weld.
it will make the down pipe install easier.
just opened the hood of my F250, looks like loads of room, but then again im running a FE 390.
Old 04-21-2015, 12:58 PM
85F350IDI's Avatar
85F350IDI
85F350IDI is offline
You've got my subscription I love bump side/dent side IDI swaps!
Old 04-25-2015, 03:58 PM
ihf-350's Avatar
ihf-350
ihf-350 is offline
just got the motor today for those following this I need torque specs please and thank you
Old 04-27-2015, 09:06 PM
ihf-350's Avatar
ihf-350
ihf-350 is offline
This is the front head off of the oil cooler the rear head/ oil filter adapter is good and so is the exchanger tube all I need is this part is it possible to get just this one from the ih dealer/ford. It is amazing it wasn't leaking yet when he pulled the motor
Old 04-28-2015, 02:16 PM
kla94's Avatar
kla94
kla94 is offline
I had a 69 F100. Loved that truck. Looking forward to seeing your progress. Only thing that would make it better is if it was a crew cab!
Old 04-28-2015, 02:48 PM
ihf-350's Avatar
ihf-350
ihf-350 is offline
I have a cc and a super cab now I needed a single lol
Quick Reply: 1969 F250 7.3l swap
