99 f350 brake issues
I'm new here an posted this in the super duty section. I've had 2 new hydroboosts in the last week PS pump is @ 3yrs old. I can finally move my 35" tires at a stop but if I'm going @50+ I loose brakes pedal gets hard. Could my master cylinder be gone? I've never had this before and everything I've read goes to pump n hydro. Only difference this time is my hydro boost when pressing the brake is loud n pulsated when I move the wheel.
on
There is a bleeding procedure in the Excursion forums that will eliminate the problem if there is air in the lines. It seems to be better than the gravity bleed.
Do you have 4 wheel ABS or just rear? Both of those will have a sensor that is located on top of the rear differential and obviously if you have 4 wheel ABS there will be a sensor on each front hub unit. Any of these could be the culprit. AE is one of the best diagnostic tools for isolating which, if any, of the sensors is going bad.
At a minimum pull the sensor out of the rear end, clean it off, and replace it to see if that clears the light. You can try pulling the front ones and doing the same.
If you are sitting somewhere in gear with the engine running with the brakes applied using the same pressure constantly, does the truck eventually start to roll?
Lastly, if you are having this intermittently, drive carefully after each attempt at fixing it. It can rear its head again at the worst possible time.
Removing the 60A fuse under the hood will restore your brakes to a semi-normal state minus ABS until you can figure this out. However, the ABS light will remain illuminated.
on
One of the reasons that I suggested pulling the 60A fuse was so that you could possibly make a determination as to whether it is mechanically related or electrical.
If you pull the 60A and your brakes are normal, minus the anti-locking feature then, maybe that points to a sensor/computer related issue.
I could be over simplifying things however it will give us more info for when the ABS experts, which I am not, see the post.
