Rear axle interchange question
Old 04-18-2015, 09:00 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
78 & 87 Super Cab is offline
Question Rear axle interchange question
Here's another one for you guys: My 1959 F100 has a 3.89 gear ratio. I would like a more highway friendly one, like a 3.23 or 3.42. What other 9" center sections will interchange with the one in My truck?
Old 04-19-2015, 02:33 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
Just about any 9 inch with 28 splines. The yoke is the only thing that might not be the same as your old one. If it's still the six banger, I'd go with a 3.50. They are the most common too.
Old 04-25-2015, 03:55 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
B7TZ-4234-A .. 28 Spline 9" Axle Shaft / R/L same / 1957/67 F100.
Old 04-25-2015, 07:13 AM
78 & 87 Super Cab
Ok thanks. Do these axle shafts bolt in, or do I need to use a slide hammer to pull them?
Old 04-25-2015, 09:35 AM
hiball3985's Avatar
hiball3985
hiball3985 is offline
Four nut/bolts that go through the axle bearing retainer and backing plate, can be accessed through a hole in the axle flange. After removing the nuts the axles sometimes will come right out, sometimes they need some persuasion.
Old 04-25-2015, 03:55 PM
NumberDummy
Old 04-26-2015, 08:58 AM
78 & 87 Super Cab
Thanks, that helps a lot!
bert cook
11-23-2014 07:03 PM
hp246
15
08-17-2007 01:35 PM
blown33
08-06-2007 10:37 AM
Quick Reply: Rear axle interchange question
