2 Speed- 12 volt Blower motor
Old 04-18-2015, 06:21 PM
dadgonebroke's Avatar
dadgonebroke
dadgonebroke is offline
I just finished installed a VDO PM351 heater motor in my 56 f100 with recirculating heat. After reading these forums- it appeared to be the recommended motor for me. Bad side is that it appears to be a single speed motor instead of the 2 speed motor that's needed. Can you guys steer me in the right direction for a heater motor (2 speed) that doesn't cost an arm and a leg?
Old 04-18-2015, 06:52 PM
firstrider's Avatar
firstrider
firstrider is offline
contact www.apartswarehouse.com ph. 1-800-409-5211 in Lake Orion .Mi. 48359
Old 04-18-2015, 07:03 PM
dadgonebroke
Thanks! I used to be your kinda neighbor (Palm City) and my son lives in PSL.
Old 04-18-2015, 07:42 PM
firstrider's Avatar
firstrider
Lived in PC '86-'92 right behind the Amoco station on the corner of Mapp & MD blvd. Been in PSL since
Old 04-19-2015, 10:32 AM
arctic y block's Avatar
arctic y block
arctic y block is offline
Cant you just use a two speed switch?
Or reducer?
Old 04-19-2015, 03:16 PM
dadgonebroke
Did a first test drive on the revamped heater and there seems to be minimal air coming out at the floor and almost nothing at the defrost windshield ducts. I'm wondering if this motor is turning reversed. Looks like it's coming back out tomorrow!
Old 04-19-2015, 03:25 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
LOL, I used the PM354, put it in about 10 years ago. I started noticing my heat wasn't directing anything to the defroster vents. Then I noticed air was coming out the TOP of the heater box! (Supposed to be going in). Sure enough, my fan was spinning backwards... I'd swear it reversed polarity on me, I couldn't be that dumb, could I???
Just reversed the leads and it's working great now. No need to pull it.
Old 04-19-2015, 04:49 PM
dadgonebroke
I reversed the leads and did a temporary connection and it works just fine now. Now to put correct wire fittings and it's good to go. After checking on the price of 2 speed motors- I think I'm fine with what I have.
Old 04-21-2015, 08:58 AM
dadgonebroke
Finished product- only 1 speed but blows twice as fast as the old motor. Hammered paint came out nice. It was actually a pretty easy job!
Old 04-21-2015, 09:21 AM
ALBUQ F-1's Avatar
ALBUQ F-1
That's gorgeous!
Old 04-21-2015, 09:48 AM
firstrider's Avatar
firstrider
Fairly easy if you start out w/ some thing in decent shape .
Beautiful result .I am impressed & I usual only do that to myself !
Old 11-20-2015, 12:26 AM
Johnnynobody's Avatar
Johnnynobody
Johnnynobody is offline
Wow, there just has to be a simple way to get an answer... Am I the only person with a 55 ford truck that needs a two speed 12 heater blower motor? and cant find any listing anywhere on these forums?
Old 11-20-2015, 12:44 AM
harleymsn's Avatar
harleymsn
harleymsn is offline
What about this one?
Single Shaft Blower Motor 1/4" Shaft CW 2 Speed, 3 Wire - School Bus Parts - A Parts Warehouse
Or this one http://www.apartswarehouse.com/show-...t-cw-rev-studs
Old 11-18-2017, 06:15 PM
dadgonebroke
12 volt heater motor
I heard a comment today that the blower motor for '71-'77 Ford Mavericks also work. Anyone have experience with this?
Old 11-19-2017, 08:03 AM
Greg Rogers's Avatar
Greg Rogers
Greg Rogers is offline
I hooked up the 6 volt positive ground motors I had to a 12 v battery w/ jumper wires, turns real fast as you would expect. Then I got a 12 v motor for a 56 and it turned slower and has 2 speeds. I wonder if you couldn't use the 6 v motor or if it would be too fast to move the air or worse burn out??? I was going to try it until I got the correct one.
Quick Reply: 2 Speed- 12 volt Blower motor
