Broncos II HELP!!
It's been a long time since I've owned it, but my old '84 Ranger with a 2.8 L. V-6 was fairly unimpressive in the power department. If you install taller tires, you are effectively changing the overall gear ratio and will have to compensate with lower gears in the differentials. Also, taller tires will make the brakes less powerful, something that these older trucks can ill afford. Their brakes are a bit weak to start with.
Unless you are willing to trash out the stock carb, distributor, and computer and emissions controls and Duraspark convert it, then you can add goodies like a hi-po cam, Offenhauser 4bbl manifold, holley 390 4v carb and edlebrock headers.
Then you can leave the guys with 4.0s in the dust.
sdkoz
12-12-2004 01:20 PM
xyz1406a1
17
11-04-2004 05:47 PM
