Sputters immediately after cold start
Old 04-14-2015, 11:38 AM
andym's Avatar
andym
andym is offline
On the first start of the day, it will crank and after it starts and I let go of the key, it stumbles once or twice, like it's not getting any fuel but then immediately smooths out and runs like a champ the whole day. Yesterday I didn't start it until 4:00 in the afternoon, and it stumbled three times.
I have the hutch mod and pre-filter. Does anyone know what might cause this, if it's a problem, and how to fix it if it is?
Old 04-14-2015, 12:04 PM
white Buffalo's Avatar
white Buffalo
white Buffalo is offline
What are the outside air temps when she stumbles?
Also, check battery voltage when the glow plugs are on and off.
Old 04-14-2015, 12:11 PM
andym's Avatar
andym
andym is offline
It was about 80 yesterday when I started it. Most times the temps are between 50 and 70. Never any colder.
Voltage is about 14.5 with the plugs off and 11.something when they're on.
Old 04-14-2015, 12:14 PM
white Buffalo
Those voltages all look very good and at those temps you don't need to worry about the glow plugs.
How many miles on the starter?
Old 04-14-2015, 12:18 PM
andym's Avatar
andym
andym is offline
I have no idea, it's probably original. It cranks and starts fine and it stumbles within a second of the starter disengaging.
Old 04-14-2015, 12:22 PM
white Buffalo
Here is what you need to start:
- at least 10.5-10.7V when the glow plugs are on. You have this
- at least 100 rpm's. Do you have a scanner or AE to check this?
- ICP of 500 psi. If you unplug the ICP sensor the PCM will not get the reading from the sensor and default to 750 psi and set a check engine light. If you don't have a scanner - unplug the ICP sensor and see if it starts different.
- PCM/IDM sync signal - this shows as 0.6ms FIPW(fuel inj pulse width). Once the other minimums are met, the FIPW will jump above 3.0 ms.
Old 04-14-2015, 12:31 PM
andym's Avatar
andym
andym is offline
I don't have a scanner. I should point out that when it's warm, it starts and idles perfectly.
When I go to start it later today, I'll unplug the ICP. Also, the ICP is only a couple of months old.
Old 04-15-2015, 07:49 PM
white Buffalo
Originally Posted by andym
I don't have a scanner. I should point out that when it's warm, it starts and idles perfectly.........
When the engine is warm or the air temps are warm?
Old 04-16-2015, 01:15 AM
andym's Avatar
andym
andym is offline
When the engine is warm. The air temps are always warm here I live.
I've noticed that if I cycle the glow plugs two or three times (and therefore the fuel pump) I don't have the problem. I am beginning to think some air is getting into the fuel system and when it sits overnight, the bubbles collect somewhere and cause the stumble when they get to the injectors.
Old 04-16-2015, 06:37 AM
white Buffalo
Possible, but it's quicker and less messy to remove the starter and see if it sounds like a baby's rattle when u shake it.
Old 04-16-2015, 03:48 PM
andym's Avatar
andym
andym is offline
I unplugged the ICP today, and this is what happened:
This is the same behavior that it does when it starts cold, but it goes away after one or two surges and then smooths out. I plugged it back in right after this and it started and drove normally.
Also, how long before the SES light goes out?
Old 04-20-2015, 08:39 PM
ExPACamper's Avatar
ExPACamper
ExPACamper is offline
Mine used to Romp-romp, then settle down when cold outside.
I changed from 15w-40w Rotella to Delo 5w-30w and it was cured immediately.
Of course, it may have been FRESH CLEAN oil, too
How many miles are on your oil?
Old 04-20-2015, 09:08 PM
andym's Avatar
andym
andym is offline
I forgot to write down the mileage last time, but probably about 3-4000. I'm pretty sure it's 15w40. I will switch to 5w40 next oil change and see if that cures it.
Old 04-20-2015, 09:38 PM
white Buffalo
The video clip sure explains it better than I imagined earlier,
Possibly a sticky IPR? You said the behavior went away after plugging the ICP sensor back in?
Old 04-20-2015, 09:59 PM
andym's Avatar
andym
andym is offline
Yeah but why? Because I started it again? Or because I plugged the ICP sensor back in?
Quick Reply: Sputters immediately after cold start
