My Trucks PO was an Idiot
Ok so finally i have most, of my Vacuum to where it should be. Also i replaced my Rotors and rebuilt my hubs... looked like they had not been greased or even torqued since the factory did them
so now having only driven my truck a handful of times i notice that my front corner lights turn on as do my dash lights when i hit the brakes... im not positive but i feel like i also hear the door adjar ding sound also when i hit the brakes... does anyone have a clue to as what this person may have done.
truck is a 1990 F350 CrewCab XLT Lariat 460
Well small update, I've replaced my fuse box my fuel pump relay switch, my turn signal switch an about 8 feet of bad wires that the PO had either cut spliced or a mixture of the two. I now have a legitimate brake light and turn signals but it seems that either side I switch on the opposite side will have a dim blink as well. Also if I turn my main lights on I have no signals. Any pointers would be much appreciated.
Received 3,166 Likes
on
Bingo that solved it. Wire brushed them all. Unfortunately now my fuel pump isn't working.... I jumped the wire at the pump it will run hit the relay w/o t run replaced the relay won't run, moved to a further point in the wiring and jumped it an it runs go back to the relay ran then stopped ugh... So separated the harness found a short right at the base of the fire wall... Jesus this truck likes to test my patience.
frankjhall
1999 to 2016 Super Duty
11-25-2015 05:41 PM
Steven_tx
08-01-2009 08:27 PM
GR8 1
09-10-2003 12:49 AM
