Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
help with rear drum brakes on 1966 f600
Old 05-23-2015, 12:09 PM
fivestarmmd's Avatar
fivestarmmd
fivestarmmd is offline
What are you torqueing to 400# the spindle nuts or wheel nuts?
Old 05-23-2015, 01:34 PM
Kevin1966f600's Avatar
Kevin1966f600
Kevin1966f600 is offline
Seating the wheel bearings, fleet told me to do 200 lbs then rotate then 400
Then back off a quarter of a turn
Old 05-23-2015, 01:47 PM
Kevin1966f600
I don't have no reason can afford to buy a torque wrench to go to 500 lbs , mine goes to ether 250 or 300 lbs, so I am going to go to my max setting then and a little more by feel with a cheater bar , and hopefully it'll work, back when I was a kid working on my old ford small trucks, i never really ever used torque wrench, but I'm older now and should know better, i am on disability because of back and neck injuries, i am trying to make a little extra and be able to pull my rv to see family in other states, thank you all for your help
Old 05-23-2015, 02:58 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,646 Likes on 1,342 Posts
I thought those numbers looked high for wheel bearings, but I find similar numbers with a quick look at an Eaton PDF for some axle, the first thing I pulled up. You should be able to search out the specific shop manual for your axle if you didn't already. Eaton has tons of them on line.
Remember the torque should be applied with the hub turning. You want everything moving as it's tightened.
Good luck with it. Don't forget the lock washer....
Old 05-23-2015, 07:08 PM
fivestarmmd
That's way to tite. My 64 5-800 says titen inner nut to 50-80 ftlbs back off 3/8 turn. if have pin locking ring line up then titen outside nut 100-150 ftlbs. should spin freely with 0.001-0.010 end play.
Old 05-25-2015, 08:42 AM
cstempert's Avatar
cstempert
cstempert is offline
Originally Posted by Kevin1966f600
I feel really stupid not looking that close at the threads, I've never heard of reverse threads on anything but propane.
Kev
Almost all medium duty and heavy duty trucks have L/H studs on driver side R/H on passenger side
Theory being as the wheel rotates the lug nut will tighten not loosen if not properly torqued
Old 05-26-2015, 10:03 PM
Kevin1966f600
Well the other side is needing done now. So I will revisit the tourqe specs, now reading i think it said 50 to 80 lbs rotate wheel, then back off a quarter of a turn, then put the dowl lock washer then tighten the outside nut to the 200 the 400 lbs
Old 01-28-2016, 11:55 PM
imjstsitner's Avatar
imjstsitner
imjstsitner is offline
I need help 68 n600 needs new drums and all brake parts and seals!
Hey this sounds like what I'm just now getting into on my 68 n600.
Maybe you can help me!
In your search for parts did you get a contact for new drums? I need 2 bad.
Where did you find most of your parts?
I'm starting with Napa or that going to be a waste of time?
Check out my thread. I think you can search by my, imjstsitner.
Thanks for any parts direction you can give me.
Old 08-20-2016, 05:25 AM
Kevin1966f600
If available, fleetpride is the place to look and way cheaper then napa
Old 08-20-2016, 11:35 PM
Stretchmobile's Avatar
Stretchmobile
Stretchmobile is offline
I made this years ago. Heavy wall tubing with a 1-1/2" socket welded on on end and budd socket on the other. I welded a 1-1/2" solid bar through the tubing. Put a cheater bar as long as you need on it. 6' usually works, although one time i resorted to a 10' bar. That time each lug nut broke free with a sound like a gun shot and you could see the rust and debris like smoke. I figured either the lug nut would loosen or the stud would break. Either way the wheel is off. Works great at pick-a-part where there are no air tools.
The following users liked this post:
gravdigr
07-06-2015 02:40 PM
jawroper
06-02-2015 08:35 PM
Jason Neuman
12-13-2012 02:15 AM
gearhead351
05-01-2007 03:09 PM
MeanOlBill
06-21-2001 08:53 PM
Quick Reply: help with rear drum brakes on 1966 f600
