1993 f250 5.8 won't start only has 130k on it
1993 ford f250 5.8 won't start it will crank and buck and fire and run for a little bit then shut right back off the plugs and wires are new the fuel filters new the fuel pump is new the ignition control is fine the crash switch is fine its just started doing this last weekend I just put the new fuel pump in still wouldn't start so I put starting fluid down the intake got it to start reved it to 3500 4000 rpm so it would shut back off then I let it come back down to ideal and I switched it to the back tank to see if the was the problem that. That fuel pump was bad then the truck die so I put it back to the front tank with the new pump and it wouldn't start again any ideas on what my problem is would be a big help the only thing I haven't checked is spark but it starts and bucks and fire so you'd think spark is fine right?
Hmm, yes I would assume it's getting spark from how describe what happened, now that you know you have fuel you should still test and make sure it has spark. Does it have any vacuum leaks?
I'm a little confused from how you worded things in your first post, so truck died when you switched to back tank and now won't start at all? Or it starts but is bucking and missing?
His 93 engine won't have a distributor thick film module he should have the fender mounted ignition control module
Also don't mess with the screw on the throttle body, it actually is not an idle adjustment
So what exactly did you get from your friend and install? unless this engine is a earlier model year swap 87-91 it should not have tfi
What color was the ICM? Grey or Black? You need the Grey ICM.
Try pulling the SPOUT connector out, and then see what it does. If that fails, then I'm guess that the PIP/Stator is failing in the distributor.
"Eric the car guy", Google that or check YouTube for Scanner Danner. There is a video that shows you exactly how to check for spark on Ford's, with TFI ignition and its a good video.
