Coolant Cavitation Eating Front Cover
We have 2 - '08 F550's & 1 - '08 F450 with just over 100k on each. One had a small pin hole in the front cover, another one was just starting to eat away. Have not had to tear down the third one yet.
Leaking 6.4 Front Cover '08 F550
Not Leaking 6.4 Front Cover '08 F450 but Showing signs of cavitation.
Ford is claiming the root cause is Improper system filling and bleeding which is believed to be the cause of air pockets in the system resulting in cavitation.
I still think it is poor coolant maintenance and not check checking the coolant for proper nitrate levels and fluid levels, and possibly the high GPM water pump the 6.4 has, but i really don't have anything solid to prove anything.
Are you running the cummins blue coolant?
bdave
10-25-2018 02:24 PM
