I need to replace the coils on the front of my F350 guys. The cc844 is the standard it seems and the cc844s is severe duty. I have a 460, which is a lot heavier than a 351. You guys think the 844s would be a lot more of a stiff ride than a standard coil?
Well, it's gonna be stiffer but acceptable I think.
I just looked it up. An F250 could have a 4.9 or 5.0 both of which are light weight engines. I can't see a 460 (dry weight being 250+ pounds more) having the same springs and being really efficient.
I think you're right. My truck had heavy duty suspension add ons fron the factory. If i hit a bump unloaded, the fillings in my teeth rattle.
Yea that's what I was talking bout riding like a brick. I'd only use 844s if you have a plow or huge front bumper with a winch. 844 should be same ride height but way better ride.
Actually I believe the 844s is 1/4" taller and since it's a good bit stiffer, might equate to a 1/2" or more with a powerstroke or 460 not weighing it down as much.
