Trust the Oil Life %
So 10,000 miles is normal between oil changes? I guess I need to get with the times. I'm used to changing my oil every 3,000. My previous ride is a 2000 expedition (I still have it). I change the oil in it every 3,000 miles, without fail. It's currently got 340,000 miles on it and is still going strong with all the original power train. Having all of that, I guess times change and they have designed these new trucks to go much further between oil changes. It's going to take me a while to get used to that.
Which engine do you have? If you said it, I missed it. The EcoBoost is a bit more picky with oil and change intervals because of it being direct injected. There is no fuel to wash over the valves to keep them clean like in other engines, so there have been cases of carbon build-up on the valves. Also, because of the pressurized intake, they are known to collect a lot more fuel in the oil. For those reasons, it is recommended to change the oil more often than 10k (most do 5k) and run a good full-syn oil. I certainly will be. If you have one of the NA engines, they can handle the longer OCIs, IMHO. I would probably still only go about 7500, or every six months to fit my annual mileage and driving style.
Here was the write up:
ROB: Copper and silicon are reading high in this report, but that's normal during wear-in, and these
don't appear to be problems. Copper comes from brass/bronze parts wearing in, and silicon is from sealers
used in putting the engine together. Both of these numbers should drop over the next couple of oil changes,
although metals may never get all the way down to average on long oil runs like this. Averages are based
on just 5,700 miles of oil use, so higher wear is okay on a longer run. Fuel at 1.3% isn't an issue and neither
is the low viscosity, so try 11,000 miles next oil.
My Blackstone oil sample directly refutes your statement on when you "should" change oil in an ecoboost motor. (at least under my driving conditions which was commuting and some towing) Everything looked great and they even recommended going longer on the next oil change which would have put me at about 11,000 miles. I had 9,689 miles on that oil sample.
Like most here, I made my first oil change on my 13 5.0 a little early...3000 miles if I remember correctly. Yes, it's probably a hangover from old thinking, but it doesn't hurt anything and probably helps with peace of mind to the owner and the only disadvantage is a few unnecessary $ out of pocket. Since then, depending on how I've been driving, the OLM has been prompting my changes anywhere from 8000 - 9000 miles. With 30,000 + miles on the odometer, I've never had to add a drop between changes. This truck just continues to put a huge smile on my face!
Fair enough. I will be sending a sample to BS in about 1 or 2k. I don't know which oil the dealership put in it, other than I'm sure it's MC. If you Google "EcoBoost fuel in oil" or "EcoBoost Carbon Buildup", you'll see where I'm coming from. While BS can tell you about the fuel in the oil, they can't tell you about the carbon issue. BTW, there still is no cleaning procedure yet, so the "fix" is replacing the heads.
The procedure for cleaning off those carbon deposits for now is put your foot in the throttle often! (until something else can be done)
No problem with that!! The other "fix" (really preventative measure) is to use a good syn oil and keep it changed to keep the PCV from sending nasty, pressurized vapors through the intake, which was my initial point. And to use a vapor trap (another mod I need to get done ASAP).
Use any oil recommended by the manufacturer.
They can all go the 10K.
The point of 10k changes is to reduce ownership cost and conserve natural resources.
Changing your oil earlier does nothing... other than waste money and provide a sense of comfort for people not wanting to accept the newer oil interval recommendations.
I go ~9500 with an oil that meets Ford specs. and probably have less wear than folks changing full synthetic at 5K.
#29
I think that's what an oil filter does.
1. Do I care about conserving resources--Yes and I recycle my oil.
2. Do I care about a few bucks for taking care of the truck--No.
3. "does nothing," you might want to read up on that. Getting the dirt out of your engine is the best thing you can do.
All I am asking you to do is read up on the subject. Bob the oil guy is pretty good, but there are others too.
