DIY camper turnbuckle: How to make a FastGun
The FastGun turnbuckle is the most popular truck camper turnbuckle for several reasons. It’s tool-free, lockable, easy to adjust and snaps into place with the perfect amount of tension every time. With this simple trick, achieve the quick-disconnect capability and convenience of a FastGun turnbuckle with any basic hardware turnbuckle.
FastGun turnbuckle
Solution: Derringer Handle
Transform old-fashion turnbuckles by adding a Derringer Handle to a basic turnbuckle chain system, standard chainless turnbuckles and even shorter length turnbuckles for bed-mounted applications. This allows for the lever action and ease of use that Torklift International FastGun turnbuckles provide. The Derringer Handle is applicable to chain systems, threaded rods and other rigging configurations.
Derringer handles for quick-disconnect capability
#1) Basic chain system
If you are currently using Torklift’s Basic SpringLoad Kit or a similar design, the Derringer Handle is attached with minimal effort.
Basic SpringLoad Kit chain system
Derringer handle attached to a hook-to-hook turnbuckle
Attach a Derringer Handle to chain turnbuckles using the following steps:
#2) Threaded rod
If you are currently using a SpringLoad XL, AnchorGuard turnbuckle or a similar design with a 1/2 inch threaded rod, the Derringer Handle is attached in two ways. Either use the eyebolt configuration as described above by hanging each turnbuckle hook bolt through the eyebolts, or create one turnbuckle unit by fastening the Derringer Handle onto a 1/2 inch threaded rod. To achieve a turnbuckle design similar to the Torklift FastGun, Torklift suggests this method of permanently bolting the Derringer Handle to the rod, creating one unit.
SpringLoad XL turnbuckles for frame-mounted camper tie downs
AnchorGuard turnbuckles for bed-mounted camper tie downs
Attach a Derringer Handle to a 1/2 inch threaded rod using the following steps:
SpringLoad XL with Derringer Handle
Derringer handles attached to threaded rod
Oh, Snap!
Now that you’ve created your own FastGun turnbuckle, enjoy securing your truck camper at all four turnbuckles in less than 4 minutes.
The Derringer Handles are produced from 100 percent aircraft grade aluminum and stainless steel and have our high impact with black powder coat finish to protect from rust and corrosion. Sold in a set of four, Derringer Handles are made in the USA and are covered by Torklift’s Legendary Lifetime Warranty.
Four Derringer Handles in one kit
Without wasting time on preparation, get on the road and find your adventure.
Click here for more information on Derringer Handles. For Torklift turnbuckle installation instructions, view the demonstration video here:
View more here: DIY turnbuckle: How to make a FastGun - Blog
FastGun turnbuckle
- Locate the drop forged steel and hot dipped galvanized eyebolts that come with each Derringer Handle
- Attach the eyebolts to each Derringer Handle by tightening it with a washer and lock nut combination (see instructions for eyebolt assembly)
- Use the hook-to-hook turnbuckle and attach through the bottom of Derringer Handle
- Secure hook bolt on Derringer Handle to the camper anchor point and tighten turnbuckles accordingly
#2) Threaded rod
- To hold the rod in place, use a wrench to tighten a jam nut to the body of the turnbuckle
- Where the threading starts, use a hacksaw and cut the rod. Bevel the top of the rod at 45 degrees using a sander, grinder or file -- Bonus Tip: Apply a small amount of paint to the newly cut end of the threaded rod to prevent corrosion
- Add a turnbuckle jam nut and adjust 5 inches from the top of the newly cut rod
- Open the Derringer Handle and insert the threaded rod through the hole in the bottom of the Derringer Handle, screw on dimple nut and tighten down
- Adjust threaded rod so 1/8 inch protrudes from the top of the dimple nut
- Pull the rod down until the nut is snug to the bottom of the handle
- Tighten the original jam nut (the one 5 inches down) to the bottom of the Derringer Handle
Oh, Snap!
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
01-16-2018 04:02 PM
Torklift Sheryl
04-10-2015 04:09 PM
Torklift Sheryl
03-17-2015 12:41 PM
Torklift Sheryl
03-11-2015 12:50 PM
