How much do truck camper tie downs cost?
Torklift has designed two different styles of tie downs for you to choose from, steel Frame-Mounted tie downs and Talon Aluminum tie downs.
Steel frame-mounted tie downs:
Front: starting at $343.99
Rear: starting at $285.99
Talon Aluminum tie downs:
Front: starting at $505.99
Rear: starting at $418.99
For trucks that have running boards or larger wheel wells, we offer Front adjustable steel tie downs that start at $413.99 and a fixed angle aluminum tie down that starts at $505.99.
How much do FastGun turnbuckles cost?
Torklift has designed a FastGun turnbuckle that starts at $323.99, and is the number one selling quick-disconnect turnbuckle in the RV industry. This turnbuckle comes in a set of two and are spring-loaded with spring tension indicators to determine perfect tension. Precision made from high impact, powder coated steel the FastGun turnbuckle is available in polished, black, white and grey.
What other types of turnbuckles are available?
SpringLoad XL: Starting off at $167.99, each set comes with two turnbuckles reaching 35” to 45”. Composed of aircraft grade aluminum and stainless steel, they have internal springs and tension indicators. This turnbuckle was designed with a square body for easy adjustment. Derringer Handles turnbuckle upgrade are available for both this turnbuckle and the Basic SpringLoad. They transform your old-fashion turnbuckle into a quick disconnect lever-action turnbuckle.
Basic SpringLoad: Starting off at $96.99, this turnbuckle bolts easily to the end of each tie down and provides the required suspension to help protect your camper anchor points. This kit comes with two quick links, two heavy-duty forged steel turnbuckles and 24” of marine grade chain.
Our tie downs, when installed properly, provide 100% support for your truck and camper. Torklift has also designed a product to secure your investment that much more! With FastGun Locks you are able to secure your turnbuckles to your tie down. The locks come with keys for convenience and weather caps to prevent damage and road grime. All our turnbuckles come with Torklift International’s Legendary Lifetime Warranty.
What’s the difference between the steel and aluminum tie downs?
All of our tie downs are frame mounted and 98% of our applications are no-drill. This difference between them is the material they are made from. The names speak for themselves. That being said the aluminum tie downs are about 50% lighter than the steel tie downs and are rust free for life. Precision crafted from high impact powder coated, light weight grade aluminum alloy they were designed for any adventure. The aluminum Talon tie downs are strength-rated as strong or stronger than Steel tie downs. For more information on any of our products contact us at 800.246.8132 or visit our website at Torklift.com.
Written By: Shyann Guerra
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
01-24-2019 06:25 PM
Torklift Sheryl
05-04-2018 02:26 PM
Torklift Sheryl
03-08-2018 07:39 PM
Torklift Sheryl
02-25-2016 12:44 PM
Torklift Sheryl
04-10-2015 04:09 PM
