It ran fine for years.. Vehicle stalled one day and would not start so I had a "pro" rebuild it.. Turned out to be ignition issue, but the carb has not worked since.. The "pro" seems to have skipped town
Thats worth considering.. However its not struggling to idle, its dead at idle completely.. It would have to be in the carb itself, as that used carb idles..
Note. When putting the top cover assembly on go straight down. Make sure Plunger #38 goes straight down over the pintle protruding up in #37. It is easy to get the #38 plunger to the side of #37 pintle, not pushing it down as it's supposed to be.
Having the plunger misaligned, well thats sure possible.. Ill look at that alignment. thanks
Also, I was told that the material (black plastic?) the floats are made of can eventually saturate and not function.
Could that cause the symptoms? Brass ones are available...
