My Baby's having surgery!
I have some really nice and expensive mud flaps, but when I accidentally backed into a low tree stump, look at what happened. The stump hit the mud flap and pulled it forward into the tire, which cracked her hip. She's at the hospital and I should get her home Tuesday.
Yup. Dodge or GM would need a lot more money to fix a boo boo like this. The bill on this is only $1100 and some change. The hip replacement is pretty easy. Soft, flexible mud flaps probably wouldn't help much at highway speed, which is where I need the most help to prevent damage to the RV. I just gotta be more careful when I back up.
Received 4,005 Likes
on
I guess with the RAM/GM it's not the entire bed but a side panel. It looks like the entire bed would need to be replaced but that would be a poor design.
A guy I know drilled a small hole in the bottom of his flaps.
He than would hook a bungy into them and pull them up when he had to back up on un-level ground or where something might catch it.
Takes a while to get used to it, and it's sort of a pita getting out and hooking them up.
But it was better than fixing flaps every weekish.
Or in this case body damage.
I need to do the same thing myself, ripped one off a while back and haven't put it back on.
Mine are the DuraFlaps also. $285.00 worth! And, yes, they are very stiff. You couldn't pull them up with a bungie cord. If there was an easy removal system, I might pull them off when not towing the RV.
