eco boost gas econ on towing
Ricky, when towing on the highway, the frontal area of the trailer makes a lot more difference than the weight. If that's a cargo or travel trailer, you are actually doing better than I would have expected.
I also wish that people would stop quoting "Canadian MPG". It's a useless and confusing measurement. But that's just my pet peeve.
Yeppers, exactly what I get too! Taller the trailer, the more drag you get, drag eats horsepower!
The "Eco OR Boost" is a very good point to consider. The whole idea of that engine is its ability to make power throughout its RPM range when needed. I would wager that if you pulled the same exact loads with the same trucks (except one having the 5.0 and the other having the EB), staying side-by-side the entire time, they would get very close to the same mileage. OF COURSE the EB is going to burn more fuel if you pull the Grapevine hammer-down on both engines because the EB will be making more power the whole time because of its turbos and torque power band ability pulling it much faster in comparison. That's kind of the point. More power means more fuel (and more air provided by turbos).
I find the pi$$ing contests between these motors (all three actually) extremely humorous. They're very different beasts with very different capabilities. Comparing all these numbers is helpful in a limited way, but you have to remember that if you pull all the time, you know the ability to get the load accelerated to cruising speed faster is handy, as well as ability to pull at higher altitudes, but it comes at a cost. It's all up to each of you to figure out what you want out of your trucks. For me, the EB was a no-brainer. For someone else, the 5.0 or 6.2 was a no-brainer...
ecoboost towing
I tow 12,000 race car trailer and a loaded truck and get 13 mpg but I have a tow tune which really helps and whenever I tow I use manual control so that I can keep the engine rpm in the low end of the power band a and helps make the small hills without dropping out of 6th.
thanks
