You have to remove the boot clamps first, then unscrew the end plug about 5 turns or remove it completely. Do you have a manual? Assembly in the correct order is essential.
If the draglink is troublesome to get apart I take the whole assembly off at the pitman arm/steering box. No need to remove it from the spindle to do kingpins
To remove the drag link on my 1950 I had to use a cold chisel shoved in the drag link cap. I had a socket on the opposite end of the cold chisel to crank the thing out. It was stuck like hell but it eventually came off.
