IT"S ALIVE!!! EFI 300 to EFI 351w swap is complete.
Because the fuel economy is nearly identical and the 300 doesn't even have enough power to get out of its own way. The 351's life span is just as adequate also.
- Ford made millions and millions of trucks and Broncos with the 300. Seems to me that if they didn't have enough power to get out of their own way they would have done something about it. You're entitled to your opinion but my F-150 was no slouch.
- 300's last longer than either the 302 or the 351. 7 main bearings vs. 5 for starters.
I don't think this swap makes a lot of sense unless your engine is dead, you need it back on the road cheap and now, and you just happen to have a 351w lying around.
- fuel economy - not identical at all. The 300 gets much better mileage.
You need the harness for the 351w.
The 300 had a long production run, true. That doesn't negate the fact that it was a gutless, long lasting engine. If you have never driven anything with power, I'm sure it feels pretty peppy though. Ford didn't need to do any updates because they sold as is. If you want to do some towing, a 351 is a better choice.
With regular maintenance, the 300, 302, 351, and 460 all have a long life span.
This swap makes perfect sense if you want some extra power for a little money.
Now if you want to add a few upgrades to a 351, sure, it will be a lot faster. But you can say that about any motor.
