Horn relay. Which one is it and how to test?
My horn isn't working. The under-dash fuse is OK and was going to check the horn relay, but can't figure out which one it is despite numerous FTE and Google searches. I pulled the cover on 2 power distribution boxes under the hood, driver's side. One box has 2 relays. The other has 4. Which one controls the horn?
Then...how do I test it to see if it's good/bad? Thanks.
The horn relay is integral to the underdash CJB. You can see if you have +12VDC going out on the wire to the horn itself(load side of relay) by probing connector C270h, pin#9 with a test light while hitting the horn button. Its a Yel/LtGrn wire. The CJB can be easily pulled out for testing by removing (4) 10 mm (IIRC) nuts that secure it to the chassis. Be very careful to identify the correct conductor. There's a lot to look at behind there.
If you have no power on that wire, double check fuse 37. If it's good, then you need to dig further. Let us know what you see.
Sent from my XT1060 using IB AutoGroup
Glad you solved the problem. Just to answer your question, the clock spring is the electrical contact under the steering wheel that is used by the horn and cruise control.
Attachment 116872
Attachment 116873
Attachment 116872
Attachment 116873
Cheers,
Nate
Craig Terry
10-07-2012 08:42 PM
