speed density roller 5.0
My truck is a '90 f150 2wd regular cab 8 foot bed. I recently installed a remanufactured '94-up f150 roller 5.0. It has a few mods such as long tubes, timing bump, msd ignition, etc. It has the original AOD trans. I have a few q's for you guys concerning performance. Keep in mind this truck is a dd.
I am currently saving up to get my transmission rebuilt (or buy a monster transmission) and shortly after installing 4.10 gears in the rear. My question here is would it be worth it to go with a higher stall torque converter (2300-2500 rpm) to help with off the line power? Or stick with the stock stall speed?
Next question is about the cam. From research I have learned that this engine already has a decent camshaft and when paired with 1.7 rr's is very close to the specs of the off the shelf speed density friendly cams. I currently have the stock rocker arms, would it be worth the money to swap to the 1.7's? Or should I go with an aftermarket camshaft?
Ok cool. I think I'm gonna go with these rockers http://m.summitracing.com/parts/crn-44746-16
Another question... my truck has way more power when the engine is cool, or right before it reaches operating temp. Its nice and snappy off the line and then when it warms up sometimes it feels kind of doggy. Is this due to the engine just being colder or is it something to do with the enrichment cycle at cold startup?
on
the less time you spend in open loop the better for mpg. you can get resistors for the IAT to make the engine think its cold all the time, its ghetto and results vary wildly, but it is noticeable sometimes. that way you can run closed loop but the computer always thinks its cold so itll richen a little, or perhaps not at all. all depends on conditions.
rb2
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
07-06-2014 11:49 AM
USMC0351fordtruckin
03-12-2011 02:51 PM
Fordenthusiasts
26
12-11-2008 10:42 PM
jav409
10-31-2005 01:18 PM
